AFR head question
Old Aug 8, 2007 | 04:38 PM
reed1951's Avatar
reed1951
Question AFR head question
I am thinking about going with some AFR 165's heads for my 71 302 (308 bored .040). At jegs they sell them with springs that hold up to .550" lift for a roller cam....I was going to use a flat tappet cam with 477''/.484'' inch lift. Would this cam be ok with those type springs, would they work well? I don't want to spend all that money for the heads and not be able to use the springs that come with them.
Old Aug 8, 2007 | 05:17 PM
HemiEater's Avatar
HemiEater
good choice.....
thats a lot of spring for that cam......run what the cam manufacture suggest
if you are going to run them, don't brake the cam in with them, use stock type springs or if they are double just use the outers.
Old Aug 8, 2007 | 05:44 PM
petes79f150's Avatar
petes79f150
You need to use springs that are matched to the cam you're using. That cam sounds like the Comp XE256H. Tyically, roller springs have higher seat and open pressures than a hyd. flat, to control a lifter that has less friction, and the roller cams typically have a more aggressive ramp profile. Excessive spring pressures are a waste of horsepower and can cause premature lifter and lobe wear. That .550 lift is a pretty vague number. I think what they mean is for the quoted price, they'll supply a spring that will handle up to that lift.I've never bought any heads from Jeg's, but I would bet if you called and gave them your cam specs, they'll install the proper springs.
Pete
Old Aug 8, 2007 | 05:58 PM
HemiEater's Avatar
HemiEater
I thought the same thing.......it don't matter how much spring pressure you have...while one is being compressed another is opening...they kinda cancel each other out.
read this on the crane or comp website....makes sense....
Old Aug 9, 2007 | 12:37 AM
darrin1999's Avatar
darrin1999
the only time you want more spring pressure is when youre revving it higher, then your lifters wont float as easy. if youre keeping the rpms down on the 302 then have some lighter springs installed... if youre trying to revv it past 5000 rpm then keep the springs they give you... itll give you better high end valvetrane stability
Old Aug 9, 2007 | 07:30 AM
reed1951's Avatar
reed1951
thanks guys, so my best bet would be for the maching shop to take the inner springs out and use the outer springs only? Cause i won't be reving it to 5000 rpms very often at all.
Old Aug 9, 2007 | 07:33 AM
reed1951's Avatar
reed1951
the springs are a dual spring set up that come with heads....with 120lb seat pressure
Old Aug 9, 2007 | 02:28 PM
HemiEater's Avatar
HemiEater
just use the outer during cam brake in if you are going to use them.....I would keep them for a future up/grade and get the right ones for the cam.
Old Aug 9, 2007 | 09:01 PM
reed1951's Avatar
reed1951
thanks guys that helps alot
Old Aug 10, 2007 | 05:48 AM
HemiEater's Avatar
HemiEater
no just get the right springs for the cam.....
Old Aug 10, 2007 | 10:08 AM
reed1951's Avatar
reed1951
oh ok, now I get ya sorry bought that
craveman85
Feb 19, 2016 07:05 AM
nandomart
1978 - 1996 Big Bronco
18
Jan 1, 2014 02:03 PM
Smidgy
Apr 15, 2012 10:15 PM
1low50
Sep 16, 2004 11:59 PM
1TUFFBRONCO
16
Jun 15, 2004 10:14 PM
