Long lasting exhaust...
Old Aug 7, 2007 | 07:14 PM
IndySilverAnny's Avatar
IndySilverAnny
I have a 91 Bronco fullsize. I paid $650 3 years ago for a complete exhaust with cat, y-pipe muffler, single in, dual outlet muffler with two tailpipes out the passenger side behind the tire, at Midas.
I lost the tailpipes last winter, and it now has some other holes in it.
Makes me sick. I couldv'e spent $200 or so more and got a Bassani SS lifetime warrantied system.
Anyway, I really would like to save some money though, and I think my cat is still good. With two kids, I also don't have time to spend a whole saturday under the Bronco cutting the old system oout, and installing a new one myself.
Are there any muffler shops where I can get a system that will last more than a couple years?
Basically, who has the best quality pipe?
Old Aug 7, 2007 | 07:55 PM
dkf's Avatar
dkf
Its not the "Quality" of the pipe, its the Material the pipe is made made out of. Sounds like your in a harsh enviroment to eat an exhaust up in 3 years. Even if an exhaust is "Stainless Steel" it may rust on you. Most exhaust tubing and components are made out of cheaper 409 series Stainless steel which has much less chromium and nickel content than the better 304 Stainless. 409 stainless will form a slight surface rust but is very resistant to rusting through like aluminized pipe. A 304 S.S. exhaust system will never rust out on you due to the higher content of alloying elements, but is more expensive than 409 S.S.
In general 300 (303, 304, 316, 321 and etc) series stainless steels are the most corrosion resistant and more expensive due to the higher alloying elements.
400 series stainless has more carbon and less alloying elements than the 300 series, however 400 series stainless is heat treatable to increase hardness, but need to go through a Passivation process to bring back its stainless properties.
Your Cat is probably good yet because most Cats are made out of 400 series stainless and only need to be replaced if they clog.
Hope that info helped.
Old Aug 8, 2007 | 08:53 AM
IndySilverAnny
Thanks for that info. I'm in Indiana, and it does get driven in the winter on the salty roads. No other cars exhaust had rusted out that quickly, and Midas put the exhaust on most of them over the years.
I just thought maybe Midas now uses a cheaper aluminized pipe than other shops.
Old Aug 8, 2007 | 09:42 AM
dkf's Avatar
dkf
Could have been the pipe. Could be cutting corners with cheap pipe to increase profit margins.
I got a Alumized steel true dual 2 1/2" out the back, glasspacks, tips and headers installed on my 74 F-100 for $240 7 or 8 years ago at a local small exhaust shop and its still on today. I used the truck as a daily driver through snow, rain and shine here in PA for about 5 years with no exhaust troubles.
The exhaust is showing its age now, but there is no rust through problems.
If you do alot of short trips the exhaust will not last as long if the vehicle warm ran for a while to blow out moisture trapped in the exhaust.
Old Aug 8, 2007 | 01:41 PM
IndySilverAnny
Up until last year, I drove a lot of long trips. 40 miles each way to work.
I now only drive 1 mile each way to work... So moisture doesn't have a chance to blow out.
Minekei just quoted $250 for a cat-back with a Cherrybomb muffler and 12" stainless polished tip. They say the Y-pipe and cat are fine. They looked fine to me also. This has a 1 year warranty only, not including labor.
I think i'm going to seriously look at a Bassani cat-back, as it wasn't much more expensive and has a lifetime warranty.
Anyone adapt this to their existing cat pipe?
Old Aug 8, 2007 | 02:30 PM
dkf's Avatar
dkf
If the replacement Cat and Y-pipe are still at the stock location the Bassani system should bolt up fine. If it was moved some custom work is in order.
A guy I used to work with lived half a mile from work and went through exhausts like crazy. He went to stainless to get more than a couple years out of a system. If it was me I probably would have rode bike or walked.
Old Aug 8, 2007 | 03:55 PM
IndySilverAnny
Well, I often pick up the kids, and it's 95 degrees right now also.
I found that Doug Thorley has a lifetime warantied system too, although it's not stainless. It's much cheaper than Bassani. It's about $270. I think I might give it a try,
FordTruckfan89
Sep 14, 2014 03:02 AM
SuperDutyDick
6.4L Power Stroke Diesel
17
Feb 23, 2014 01:06 PM
Gary Atsma
2009 - 2014 F150
Sep 5, 2011 05:32 PM
boxcar1974
Modular V10 (6.8l)
Aug 27, 2007 07:52 PM
