6.4 / Mini Max / Turbo Back Exhaust
6.4 / Mini Maxx / Turbo Back Exhaust
<HR style="BACKGROUND-COLOR: #ffffff; COLOR: #ffffff" SIZE=1><!-- / icon and title --><!-- message -->After going through all the ordering, installations and set-up, I thought I'd share with other 6.4 owners a couple of tips if you installing a Mini Maxx on you truck.
First of all I ordered a new exhaust "AFE" Turbo-Back with muffler and bungs along with my Mini Maxx. Since my truck is a 2008 Extended Cab, short box it's wheel base is only 142" long. AFE doesn't provide an exhaust for that size. The one I received was for a 156" to 172" wheel base. When assembling the system I soon found out that the system was way to long for truck. The system I ordered was a 49-13022. There are 3 pipes + the muffler and tailpipe with this system. I had to remove 22" off the tailend of the 3rd pipe back including the hanger (called mid-pipe 3). I removed the factory hanger from the frame of the truck as well. I then had to remove 8 1/2" from the tailend of the 2nd pipe (mid-pipe 2 [dpf delete pipe]). I then had to reverse the clamp that came for the rear of the muffler so that the tangs were facing the rear of the truck (the instructions show them facing forward like the factory installed hangers). Once everything was cut, everything fit perfectly. I installed all the sensors with some adjustments to the pressure sensor bracket. Everthing is working great and sounds awesome. Nothing like hearing the turbo breathing through the tail pipe. I just found out that H&S says to unplug all the sensors to the exhaust system. When I called them about why, they said that the Mini Maxx neither talks to or uses those sensors. They advised that I unplug the sensors, remove them from exhaust system and to plug the bungs. It would have been nice to know all this before I ordered the exhaust so that I could've ordered it without the bungs. Advance Deisel is sending plugs for the bungs, but I have to pay for them. By the way, Advance Deisel and H&S Performance have been very helpful and reply almost immediately with their responses. It would have been nice to know when ordering that it should also be broken down by wheel base. Techically they don't make an exhaust for 142" SuperDuty but I was able to make it fit. It all comes down to if you have a 6.4 and order a Mini Maxx you don't need bungs and you don't need any of the factory sensors. As soon as the rain quits I want to take the truck for a ride to get the transmission to relearn it's shift points. Even at the "no power" setting it will set you back in the seat. I can't wait to see what "Hot" setting is going to do. So far all I can say is WOW!!! I'll post later with what my mpg gains are. So far I changed out to an S&B cleanable filter system and had an immediate 4mpg gain.
The Hot settings are awesome, I just Installed my MiniMaxx a little over a week ago. I like it alot. Transmission relearn isn't hard at all due to the fact the truck gets up to 80 mph pretty darn quick. Just a reminder always tow on No Power setting. Once you go to the Hot setting your not going to want to go back to the no power setting.
Why not just use the sensors to plug the holes and leave them plugged in to keep the plugs clean? If the truck doesn't use them I can't see why it hurts to leave them in.
H&S is the only company doing a DPF delete, turn off EGR and leaving everything else stock tuned aren't they? Planning on going that way very soon since the warranty is just about up.
the Hott Damn tunes are +50hp,+125hp,+225hp,+300hp. Easy tunes are +0hp,+60hp,+120hp,+175hp. There is a product out there that just deletes the equipment and is not a tuner/programmer ( Gear Box Z ).
2008 F350 6.4 turbo diesel
Ok... I'm soooo confused. When I bought my truck it was getting 18 city and 22 hwy. took I it to Ford for routine service and they reset my computer and I was getting 8-12mpg. I assume they deleted a performance program not a dpf delete??? I just want my gas mileage back!! I was going to do a performance chip and cold air intake, but the parts guys said I would be better off doing a dpf delete. Now I don't know what to get. (Yes, I am a girl and trying to do this all by myself). I am also blonde, so if you guys can speak in plain English and not guy car talk, I would appreciate it. . HELP!! Thanks...
Ex husband did the mpg by hand, because he couldn't believe how good it was getting. It was real close to what it was reading. I just want to open her up and let her breathe and get some extra mpg without spending a fortune. Can't see spending over2k and not making that money back up in gas. Thanks for your response.
If you were actually checking the mileage the old fashion way and its that bad then I might be tempted to take it back and see what they did. Anyways give us some more information and maybe we can help you out some more, I'm just taking a stab at this so who knows if I'm right or wrong.
IMHO...I haven't heard anyone gain 4mpg...with an intake.. I added my stage 2 afe...got maybe a 1-2mpg.. keke... I think if you had a 2wd single cab f350 with stock wheels/tires.. you might have got close to 18/22...but a f350 4wd crew cab getting 18/22 would have to have a crazy set up to achieve those numbers...the 8-12 sounds right if your doing a lot of stop/go in town driving which kills every1's mpg. I have a mini maxx 250hp setting/afe stage 2 intake/flo-pro exhaust..getting 12-14 in town...im also lifted though...I'm happy with it!
