Sponsored by: Auxito
whistleing noise
Old Aug 7, 2007 | 06:51 PM
sudical's Avatar
sudical
whistleing noise
97 f-150 4x4 4.6 liter makes a whistleing noise when i let off the gas and when i turn it off at shut off it will maintain a whistle for up 2 or so min
Old Aug 7, 2007 | 10:10 PM
ncranchero's Avatar
ncranchero
Vacuum leak. Take a short piece of hose, garden hose is a good size, and use it like a stethoscope to locate the "whistle".
Old Aug 9, 2007 | 09:55 AM
douboy80's Avatar
douboy80
you can also use b-12 chemtool and spray around the intake and all vaccum lines and when the motor tries to die thats where the leak is but remember you are useing a flameable substance so keep in mind that it is best to have a fire putter outter thingy around
Old Aug 10, 2007 | 12:07 AM
LxMan1's Avatar
LxMan1
Sounds like a bad PCV hose elbow. Quite common.
