Sponsored by: Auxito
Check engine light...........
Old Apr 27, 2002 | 03:28 PM
RIPBIG3's Avatar
RIPBIG3
I have a 1998 for F150 and the check engine light came on today. It have a little hesitation when this happened thats how I noticed the light. It has 56K miles on it and I have never had a bit of trouble with it. I read the owners manual and it said that light is mainly for emission trouble. I have filled it up with fresh gas and added some gas treatment to it in case I got some bad fuel. Is this a bad PCV valve or something I can fix myself or will I have to take it to the dealership? Thanks it advance for any advice.
T
Old Apr 27, 2002 | 04:04 PM
Yellardawg's Avatar
Yellardawg
[updated:LAST EDITED ON 27-Apr-02 AT 05:05 PM (EST)]The check engine light is for any error code that might come up. It can be anything on your computer. You should buy a code reader, find a code reader, borrow a code reader...go to a mechanic with a code reader etc...and have the code read before going at it blindly.
Good Luck
YD (Autozone will read codes for free)
bet it is a 300 series code
Old Apr 27, 2002 | 06:57 PM
Ultramagdan's Avatar
Ultramagdan
As Yellardawg said it could be anything. However, if you are in a bind and cannot make it to a code reader. Disconnect your battery for 20 minutes and then restart it. If it's a real problem i.e a sensor has failed, it will come back on shortly. If it's a sensor slowly starting to read things a bit off it may take several thousand miles before the light comes back on.
I took mine to AutoZone today. Both banks are running lean but that was it - it showed nothing had failed. The tech said it was probably one of the O2 sensors dying a slow death in it's ability to read emissions. So he said to wait untill it shot craps for good.
Sure beat paying somebody a $100. Costs was zip. And my light is still off after driving 40 miles.
Old Apr 28, 2002 | 08:01 PM
diceman77's Avatar
diceman77
Hey man, same thing happened to me with similar milage on a 98 F-150. All that was wrong was the O2 sensor but I imagine it could be something else but I would bet on that. Anyway hope this can help.
Old May 5, 2002 | 09:04 AM
PHDguy's Avatar
PHDguy
Hey all, I have a 1998 F-150 extended cab, 4.6 litre V8. My Check Engine light started blinking yesterday shortly after my engine started running rough. after a few minutes it stayed on. Where can I go to get it checked out without paying a fortune? Is there anything I can do as a Novice to fix this?
Would disconnecting my battery help, or because it is running rough, should I just take it in?
Where can I get a Code Reader at a reasonable price....along with the instructions on how to use it?
Old May 6, 2002 | 05:47 AM
brud98's Avatar
brud98
FYI - I have a 98 f150 4x4 with a 5.4 and I ran into the same problem error. After reading the manual I learned that all it was that the gas cap wasn't on tight enough. Sure enough the light went away when I tighten the cap. Sometimes it's "good" to read the manual!!:P
Old May 6, 2002 | 01:55 PM
p_white's Avatar
p_white
Post Check engine light...........
You probably had a mis-fire. I believe Autozone will read the code for free which will confirm the mis-fire and tell you what cylinder. If you want to buy a code reader, most parts houses sell them for about $150.00. As far as a solution, it is probably a bad wire, plug or coil. You can trouble shoot it yourself once you know the cylinder missing by swapping wires or plugs or coils. I recently had the problem and changed the wires and plugs and still had the problem so I changed the coils and still had the problem. Turns out one of the new wires was bad. Replaced that and all is well. I had over 100K miles so it probably was good that I replaced it all. Incidentily, I went from getting 15 mpg to 17 mpg. F150 4x4 4.6 Ext. Cab.
Old May 8, 2002 | 05:05 PM
myke's Avatar
myke
The blinking check engine light means the computer has sensed a misfire. If the misfire clears up the light goes off. After x number of cycles, if it still senses the misfire it puts the CE light on & sets a code. This happened with my E150. Turned out to be a bad coil (my 5.4 doesn't have spark plug wires. Each cylinder has it's own coil.) A code reader will tell you which cylinder is causing the problem. Betcha it's the coil. When my mechanic called to order the part they said they had 5 in stock "cuz they go out all the time."
Old May 15, 2002 | 09:13 AM
JDHOGFXSTC's Avatar
JDHOGFXSTC
I had this exact problem but it went on for months, I would pull up to a light and the truck would start to miss, the CEL would flash then come on. The dealer said it was a missfire and finally changed all of the plugs and wires. They paid for the Wires. My truck has 85k 4.6 w/5spd
Old Aug 3, 2002 | 02:35 PM
ActionHero's Avatar
ActionHero
Check your negative battery cable terminal for corrosion. My chk engine light came on for that reason. Cleaned it and light disapeared.
Good Luck...
Old Aug 5, 2002 | 09:34 AM
chrisindallas's Avatar
chrisindallas
I had the same thing. My check engine light came on and I took it to Auto Zone. The first one I went to came back with a O2 Sensor problem. But that was before Autozone had all of their codes computerized. Over the weekend I went back to see if I could get more detail on which bank and such it is and there were 2 codes. THe guy at the first forgot to scroll through and see if there were more than one. I had a "System too lean" and that caused the "o2 sensor is slow to respond" A full bottle of Fuel Injector cleaner on a quarter tank of gas did the trick. (I may have made a potent mix ) Drove it for a while and no light. If it comes back on I will check it out again and possibly take the sensors out and clean them off with electrical comnponent cleaner. (As read on another post)
FYI. I have a 99 f150 xl with 78k miles.
Old Aug 6, 2002 | 07:57 AM
ericatUNC's Avatar
ericatUNC
Guys, I am having the same problem right now on my 1998 Ford F150.
It was misfiring, the light would blink then stay on and whenever I'd give it gas, like going up a hill, I would feel hesitation. I took it to AutoZone and the code was 304 - Cylinder 4 Misfire. The guy there told me to start with replacing spark plugs, which I figured was a good idea. Then if that didn't help, replace the wires, etc.(by the way, I am a novice, know nothing about this ..)
Anyway, I got the spark plugs and gapped them, then started the easy task of replacing them...wrong! How in the heck do you get those spark plug wires off?? I pulled my *** off and got no where. I was able to get #1 off, then I went to #4 and tried for an hour, even went and bought a spark plug wire puller and still couldn't get it.
Before I started, I did disconnect the battery and cleaned the terminals, when I finally gave up last night, I put everything back together and started my truck and the light has not come back on, nor has it hesitated...for now.
I want to do this myself, and replace those plugs, does someone have tips on how to get those wires off?
Thanks,
Eric
Old Aug 6, 2002 | 06:27 PM
Mad Jack's Avatar
Mad Jack
Hi there,
The best way to get the spark plug wires off, is to use a pair of pliers and pinch the ends of the spark plugs which will automatically release the spark plug.
Mad Jack
aka Andy Blackwood
mad.jack@shaw.ca
Old Aug 6, 2002 | 08:55 PM
scooby3_4's Avatar
scooby3_4
i having the same problem with mine it a 4.6 the shop that looked at it has replaced egr, egr solinoid wires plugs coil pack and o2 and still the light comes on
Old Aug 6, 2002 | 09:39 PM
deucester's Avatar
deucester
FourXFord2
1978 - 1996 Big Bronco
Jan 1, 2016 07:22 PM
troupstree
13
Jul 9, 2014 09:07 PM
TheEif83
2004 - 2008 F150
Mar 16, 2010 05:11 PM
Billy Ray
Jan 3, 2004 07:57 PM
seagull369
Computer Chips & Tuners
Jul 1, 2003 10:43 PM
