Hood Hinges
Old Aug 7, 2007 | 01:20 PM
magee's Avatar
magee
Hood Hinges
I've tried a search and couldn't find what I was looking for although I know I've seen it here before. The hood hinge on the driver's side doesn't let the back of the hood sit where it should. The rear corner is about a half inch higher than it should be. Is there a way to repair the hinge or do I just need to bite the bullet and spend the $60-$80 per hinge and replace them? Whoever can save me the 120+ bucks with a good way to save the originals will earn the privilege of buying me a beer to celebrate.
Old Aug 7, 2007 | 03:37 PM
bertha66's Avatar
bertha66
I at one time took the driverside hinge and cut the bolt holes into longer slots to lower the hinge down, it did work for a time, but it is sticking up again. I will be getting new ones at sometime.
Old Aug 7, 2007 | 04:11 PM
cobraguy's Avatar
cobraguy
It has been discussed here a while back. Somebody took their hinges apart welded the oblonged holes and redrilled them round. replaced the rivets with bolts and even put teflon washers in. I know that if your hinges are worn removing the spring will make it so the hood sits flat, you may need to push the rear edge down. If it dosen't settle with the springs removed then check all your body to frame pads, especially the core support and front cab mounts.
Old Aug 7, 2007 | 07:42 PM
daveengelson's Avatar
daveengelson
Here is an archive post in 61-66 forum on topic. Have seen it in other forums so may try running a search and see if able to find some additional info.
https://www.ford-trucks.com/forums/4...t=hood+hindges
dave
Old Aug 8, 2007 | 06:39 AM
magee's Avatar
magee
Thanks, guys. Dave, I think that was the posting I was looking for. I just didn't think that it was that long ago.
Old Aug 8, 2007 | 07:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C2TZ-16796-C .. Right Hood Hinge
C2TZ-16797-C .. Left Hood Hinge
Fits: 1961/66 F100/1100 & 1967/69 F800/1000
Old Aug 8, 2007 | 01:30 PM
cobraguy's Avatar
cobraguy
I knew I'd seen that thread. I actually posted in it. My old hoods hood to hinge brace was collapsed. When I replaced my hood it sat flat.
HillBillyBuddha
Apr 22, 2014 04:23 AM
thepitshop
19
Dec 13, 2010 12:05 PM
jreeder41
Aug 19, 2010 10:48 AM
ibuzzard
Aug 3, 2010 10:44 AM
BensDaddy
Projects
Jul 3, 2008 01:17 AM
