Brakes Help!!!!!!!!
Old Aug 7, 2007 | 07:35 AM
fbilly420's Avatar
fbilly420
Exclamation Brakes Help!!!!!!!!
so the last couple days since sunday i noticed a little squeak in the left front so yesterday (monday) i pulled the locking hubs to check the the needle bearings and they looked great. The truck ran great and drove just fine but on my way to work this morning when i hit the brakes it pulls HARD to the left do you guys think it could be the wheel bearing? or do brake calipers just give up that fast?
any thoughts are greatly appreciated thanks in advance,
Billy
Old Aug 7, 2007 | 07:49 AM
Ed in Maine's Avatar
Ed in Maine
I would replace the front pads and be sure you lube up the sliders that are inside the rubbers slinky looking boots. The prev own put new pads and rotors on my truck about 5k before I bought it but the pads wore wicked uneven, I believe due to the sliders not being greased well. Because it pulls when breaking, would not think the wheel bearing is bad. Unless your hubs are locked accidentally, your needle bearings are not spinning so you can cross them off the list. They can make a clunking sound if they are real bad though (because if the half shaft slapping around when cornering...).
Old Aug 7, 2007 | 07:53 AM
Kwikkordead's Avatar
Kwikkordead
Billy
Check the right front. When something gives up the vehicle always pulls to the good side because it's doing all the work.
Old Aug 7, 2007 | 07:58 AM
fbilly420's Avatar
fbilly420
well about two weeks ago my brakes were shaking like warped rotors so i pulled the front wheels and greased the caliper slide and checked the pads the pads were wearing straight and only one slide was dry, it was on the left side. I cleaned up the rust from the pin and greased both slides on both sides. I am still concerned about the wheel bearing because i lost one in my 98 ranger and it took out the caliper, bracket and rotor but i am sure on this truck those parts are alot more expensive so i dont want that to happen again
Old Aug 7, 2007 | 08:00 AM
fbilly420's Avatar
fbilly420
i am going to pull both front wheels today just have to wait for my lunch break. Just dont want to over look anything.
Old Aug 7, 2007 | 10:50 AM
just another truck's Avatar
just another truck
Like Kwik said, look at the right front,doesnt hurt ot look at both sides, but the right front shall be the source of your entertainment
Old Aug 7, 2007 | 11:53 AM
Fat Diesel's Avatar
Fat Diesel
When my hub bearings were going bad I could hear the WUMP WUMP WUMP WUMP as I took a long fast turn.
Old Aug 8, 2007 | 11:25 AM
fbilly420's Avatar
fbilly420
well i pulled both front wheels, removed calipers and pads clean with brake clean and compressed pistons to make sure they were not siezed and both side were ok. pads have over 1/2" and wearing evenly. I have found that if i give one little pump before appling hard on the brakes it does not pull hardly at all and i am puzzled.
anymore thoughts or opinions?
thanks, Billy
Old Aug 8, 2007 | 11:31 AM
just another truck
did you look at the slide pins.....
Old Aug 8, 2007 | 11:32 AM
fbilly420's Avatar
fbilly420
yes all four on the front are greased and slide with ease.
Old Aug 8, 2007 | 11:34 AM
just another truck
Have you had the calipers off, any oil leaks, Does it jerk, then straighten? I am kind of thinking air in the line.
Old Aug 8, 2007 | 11:44 AM
fbilly420's Avatar
fbilly420
the calipers were off but the brake line connected, there are no leaks, if i have to step on the brakes hard i have to turn the wheel over a half turn. I think tomorrow i can try and bleed them do you think the rear brakes could cause a pull this serious because i havent checked the rear.
Old Aug 8, 2007 | 11:51 AM
just another truck
no, i have never experienced anything with the rears causing a pull, and I have had a wheel seized.....
Old Aug 8, 2007 | 12:04 PM
chriz501's Avatar
chriz501
Maybe this will help.
This same problem happend to me on another vehicle. The problem ended up being a bad brake line on the opposite side of where the vehicle was pulling.
Old Aug 8, 2007 | 01:02 PM
fbilly420's Avatar
fbilly420
i thought about the rubber brake line swelling when you apply the brakes but i need someone to press the brake so i can watch the line i will have to look thanks.
