We need some measurement!
Old Aug 7, 2007 | 07:51 PM
havi's Avatar
havi
I'll have the Roast Duck
so is the 53-56 lower than the 48-52, stock? I have my axle beam resting on a wheel dolly, which puts my front spindle at 9", my rear wheel center is 13". My front bumper is 11". So adding 4" to my front spindle to even it up with the rear wheel, would make my bumper about 15". If I add a 3" drop axle & reverse eye mains, I may get it down to 10". Any lower than that where I live and I won't make it over the RR tracks, or survive the potholes from frost uphheaving. '48 F1
Old Aug 7, 2007 | 08:17 PM
e william's Avatar
e william
Hi all,
my front is 11" to the bottom of the frame and rear is 21"
I have a reverse mono on the front and have a lowering shackle and remounted the rear-forward shackle 1.5" lower on frame. I have removed two leaves from the rear stacks and might take another out when I check the ride on road.
later, Ed
Old Aug 7, 2007 | 11:10 PM
51dueller's Avatar
51dueller
I'm going off the top of my head but 16" seems right. What if your front bumper doesn't fit anymore?
Old Aug 8, 2007 | 12:22 PM
brucewolff's Avatar
brucewolff
Originally Posted by CharlieLed
Was at 7, now at 3-1/2 but haven't gotten the new tires and wheels installed yet...should come up a tad.
Oh you have a "road grader" then.
Old Aug 8, 2007 | 01:02 PM
53fatfndr's Avatar
53fatfndr
I'm at 7-3/4" from the bottom of the bumper, and 6-1/2" to the bottom of the license plate. Before I got it aligned and straightened up I was less than 5".
Old Aug 8, 2007 | 01:39 PM
B/B ford's Avatar
B/B ford
Clean & Classy
John, your truck looks like it sitting just about where mine was originally. It looked great at that height but scraped on everything. I,m now running the Big Block MII springs from T.C.I. and it seems just about right.
Old Aug 8, 2007 | 01:42 PM
mt54's Avatar
mt54
My front bumper is 1/4" off the ground in the center and actually is in the weeds.....
Oh wait you meant on the truck didn't you ?
sorry no bumper....
Old Aug 8, 2007 | 06:48 PM
e william's Avatar
e william
Originally Posted by e william
Hi all,
later, Ed
Let me correct the info a little....ground to bottom of gravel pan is 9 1/4"
and ground to bottom edge of rear fender is 14"
Old Aug 9, 2007 | 02:13 PM
GreatNorthWoods's Avatar
GreatNorthWoods
I finally got around to measuring my 48 F-3 today. It's 10.5 inches in the front and 15 1/4 in the rear. Front is Volare IFS. Rear is above the springs Chrysler with Chrysler leaf springs. I'm running 225:75/R15 tires on all four corners...it's about right for me.
Old Aug 9, 2007 | 08:29 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I've been out of town all week, just got in and took a tape out to the truck. My 49 is at 13" from the bottom of the front bumper to the ground.
Bobby
Old Aug 9, 2007 | 10:05 PM
fatfenders56's Avatar
fatfenders56
Had to walk out to the garage and check, 6 1/4 inches, 5 degree rake
Old Aug 9, 2007 | 10:48 PM
fatfords's Avatar
fatfords
Mine's at 8 3/8" with a Camaro sub, but likely to increase as I'd like to lower the rear another 1 1/2" to 2".
Old Aug 10, 2007 | 08:40 AM
  #28
Randy Jack's Avatar
Randy Jack
The engine is not in it now and the bumper is now removed. However, it was 8-1/2 to the bottom of the bumper before I tore it down. I plan to add 2" spacers over the MII coils before it goes back on the road because it was dicey over speed bumps and parking lot bumpers/curbs. That will save some scrapes on the bottom of the gravel pan.
Old Aug 11, 2007 | 02:31 AM
  #29
gusso's Avatar
gusso
Mine has the original straight axle and its 10 1/2" to bottom of front bumper
Old Aug 11, 2007 | 09:23 AM
  #30
fatfenders56
I fit doesn't scrape, it isn't low enough!
