1966 - 1977 Early Broncos
Fuel starving problem
Old Aug 6, 2007 | 06:56 PM
Baja FX4's Avatar
Baja FX4
Post Fuel starving problem
hello all,
Wondering if anyone has any ideas.
My boss has a 1971 bronco with a 302.
The thing is cherry,runs real good when first started and motor sounds very healthy.
The problem is,it has a clear fuel filter mounted in front when it first starts,the filter is almost full with the engine running.
But after it runs a while,the filter dries up and the engine starts starving for fuel.
He tried a new carburator,cleaning the lines and a new electric fuel pump.
Problem still there.
he says he dropped the tanks and they were clean.
It has a small holley carb,and a holley mechanical fuel pump.
Any ideas?this would probably mean a nice raise for me if I get it running good. : )
any help would be appreciated.
Old Aug 7, 2007 | 12:34 PM
BoltBuster's Avatar
BoltBuster
He is getting a vacuum lock in his tank....What I mean by vacuum lock is that your not allowing air to go into the tank as the fuel leaves.
This is caused by a tank not being vented or plugged or the fuel cap has no vent or clogged. Buy a vented cap or add or trace out the vent line for the fuel tank(spiders, hornets and mud dobbers are known to clog these tubes)
Let me know what you find?
winginit
Sep 12, 2016 11:02 PM
woodjunkie
68
Aug 18, 2016 07:59 PM
privateer, eh
20
Jan 28, 2014 06:11 PM
beest
Mar 19, 2011 07:07 PM
SidecarFlip
General Diesel Discussion
Sep 28, 2010 10:48 PM
