Spark knock
Old Aug 6, 2007 | 06:48 PM
roadrunner doug's Avatar
roadrunner doug
Spark knock
I have had a apark knock and missing problem about 6 months now.It is only under load.The motor misses and knocks.I have been running mid grade fuel lately and seem s to help.I had done a tune up to help,I thought it was a miss.I was told to watch the routing of plug wires on a 351.Spark jump.So I changed them.Any ideas.WE did a fuel ijector and throttle body cleaning also,and fuel filter.Thanks
Old Aug 6, 2007 | 06:57 PM
mstrelectrician's Avatar
mstrelectrician
check your ignition timing, around here gas seems to be of a lower quality more and more. Plug wire looms may help. If all else fails check your timing chain, total engine timing.
Old Aug 6, 2007 | 07:11 PM
roadrunner doug
My buddy said that if we reset the timing the computer will reset it back.The truck has 160.000 on it.Do you think it will help???Thanks for the responce.
Old Aug 6, 2007 | 07:39 PM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
Do you have any codes? Go here and check for codes
http://www.fordfuelinjection.com/?p=13
My 5.0 was missing under load......Might have been pinging too....i'm too hard of hearing to know......
Anyway......I got the plug wire routing info and re-routed my wires (new ones) and it stopped.
Here's the info..
https://www.ford-trucks.com/forums/6...e-routing.html
Believe me.....you have to follow it........try that and see.
At 160k your timing chain could be going bad......causing it to be out of time some. Get a timing light and check it, see where it is and if it's where it's sposed to be. Resetting the computer isn't going to change the timing if it's a bad chain.
Good Luck
Bob
Old Aug 6, 2007 | 08:27 PM
roadrunner doug
Thanks,does that apply to the 5.8 or 351 the same???
Old Aug 7, 2007 | 08:13 AM
92F150Flare
Look at the different pics that bobcf put in there....the 1,3 and 1,5.......both 5.0 and 5.8.
Old Aug 7, 2007 | 05:48 PM
lostin90s's Avatar
lostin90s
I'm workin on same thing without miss. Clean Iac and check egr for sticking as well as check for vac leaks . What they told me to do in injection forum .I just did get to do yet .
Old Aug 10, 2007 | 03:51 PM
EPNCSU2006's Avatar
EPNCSU2006
The computer cannot adjust absolute timing, it can only adjust timing relative to the set point, which you can change. Retarding the timing a degree or two may help, depending upon where it is set now. If it is set at 10° BTDC now, there's another issue that needs to be resolved. Retarding the timing is only masking another problem.
