differential ratios
Old Aug 6, 2007 | 03:57 PM
SD44's Avatar
SD44
differential ratios
hello everyone,
just joined today, this is my first post.
my first question is.....does the door tag have a code that tells the ratio of the rearend? the tag is gone off the chunk on my 76', so i was hoping the door code could help me.
thanks
Old Aug 6, 2007 | 04:10 PM
Matts72's Avatar
Matts72
You will need rear end tag or the sticker on the door jamb. If none of these are present you can request a build sheet from ford which will give all the factory build specs for you VIN.
We can narrow it down if you give us as many details as possible...
Old Aug 6, 2007 | 05:32 PM
classicranger's Avatar
classicranger
Smile
The tag being gone means someone has been in there more than likely.
If you want to know your gear ratio you can check it by
marking the driveshaft at the ujoint and third member
then jack up one side of truck and mark the tire (i use the tire valvestem at 6 0clock position)
turn the tire 2 revolutions and count how many times the mark on the ujoint goes past the mark on the dif.
this will be your gear ratio 3 and half turns will be 3.50, 3turns 3.00 and ect.
Old Aug 6, 2007 | 09:07 PM
Mil1ion's Avatar
Mil1ion
If the truck is a 77/78/79.
See Position 12 on the rating plate for rear axle code
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Aug 7, 2007 | 09:34 AM
SD44's Avatar
SD44
how can i tell if it's a posi/locking rearend?
Old Aug 7, 2007 | 12:13 PM
Mil1ion's Avatar
Mil1ion
The easy way is to do a burn out. If both wheels leave a rubber mark tou have
LS or Traction lock
"Posi" is a GM term.
The hard way is to jack the rear of the truck up and check them.
Old Aug 7, 2007 | 12:38 PM
SD44's Avatar
SD44
i was needing to know how to check for a locking rearend on a junker in a salvage yard. is it on the door code, or can i tell by rotating one of the tires?
Old Aug 7, 2007 | 01:09 PM
X36's Avatar
X36
You could try jacking up the back end and spinning a tire, if the other tire spins the same way you have a locker, if it spins the opposite way or doesn't move it's an open diff.This provided nothings worn out inside Regards and Welcome
Old Aug 7, 2007 | 01:23 PM
SD44's Avatar
SD44
but if one tire is still on the ground so it can't turn, wouldn't the tire that's up in the air still turn even if it is locking, because aren't locking rearends actually "limited slip?" I've been told in the past that with limited slip, one tire makes 1 1/2 revolutions before the other tire starts turning. correct?
Old Aug 7, 2007 | 01:49 PM
X36's Avatar
X36
My mistake in my 1st post I should of said limited slip not locker. A "limited slip" or "posi" is just that, clutches activate within the pumpkin. They are activated due to each tire turning at a different ratio or speed, A "locked" axle doesn't care, they (tires) turn at the same speed all the time by having a set of locking teeth in the pumpkin.Our trucks never came off. the line with lockers only limited slip.to tell if a rear end has it due what I said in the 1st post.To tell if it has a locker (non-factory) ya gotta open the pumpkin and look for the locker
Old Aug 7, 2007 | 01:53 PM
SD44's Avatar
SD44
so if i get both rear wheels off the ground and spin one forward and the other wheel also turns forward, then it's limited slip, right? And if the other wheel turns backwards, then it's open, right?
Old Aug 7, 2007 | 02:01 PM
X36's Avatar
X36
Yes that is correct
Old Aug 7, 2007 | 06:27 PM
Dustin1690's Avatar
Dustin1690
[QUOTE=Mil1ion]The easy way is to do a burn out. If both wheels leave a rubber mark tou have
LS or Traction lock
okay hate to break it to you man but i got no LS the axle code is 19 on my 1993 i have done a burnout like stepped on it and on pavement its lets 2 wheel marks what gives? iam 100% sure its stock cause in winter one wheel would spin
Old Aug 7, 2007 | 09:53 PM
Matts72's Avatar
Matts72
Also, you could have a limited slip with worn out clutches and it won't do a 2 wheel burnout...
The best way to tell is to pull the 3rd member and do a visual inspection.
jyblood
Feb 16, 2014 03:25 PM
TurtleRacing
21
May 7, 2008 03:28 PM
JAY95gt
Mar 11, 2007 09:51 PM
thayer69
Mar 11, 2003 07:23 AM
ol_geezer
Feb 22, 2003 09:41 AM
