OBD II Code
Old Aug 6, 2007 | 10:48 AM
pctjk's Avatar
pctjk
OBD II Code
I have a 99 F250 SD 7.3 PSD Service Engine light came on today. Pulled the code 1395. What does this code mean and how do I repair?
Thanks in advance for any and all replies.
Jeff
Old Aug 6, 2007 | 11:12 AM
Pocket's Avatar
Pocket
What scanner are you using? There is no P1395 code.
Old Aug 6, 2007 | 11:18 AM
cgl's Avatar
cgl
This is correct. There is no 1395. 0305 and 1316 are the only two that come even close to that combination. Are you having any symptoms?
Old Aug 6, 2007 | 12:37 PM
guzzle92's Avatar
guzzle92
I am showing - P 1395 Glow Plug Monitor Fault Bank No. 1
California Truck?
<table style="table-layout: fixed; width: 456pt; border-collapse: collapse;" x:str="" align="center" border="0" cellpadding="0" cellspacing="0" width="80%"><tbody><tr style="height: 12.75pt;" height="17"><td style="height: 12.75pt;" height="17">
</td> <td>
</td></tr></tbody></table>
Old Aug 6, 2007 | 01:21 PM
cgl's Avatar
cgl
California Truck?
</td> <td>
Interesting... Is this a 99 MY code? I have a PDF from "FORD MOTOR COMPANY REVISION DATE: FEBRUARY 14, 2003" and all of the glow plug related codes are in the 06xx range. Of course this is for MY2002 and I assumed it was backwards complaint.
Old Aug 6, 2007 | 01:29 PM
tamte65's Avatar
tamte65
I have the same in my list, here's all to Glow Plug circuit:
<TABLE style="TABLE-LAYOUT: fixed; WIDTH: 456pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width="80%" align=center border=0 x:str><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P1389</TD><TD> Glow Plug Circuit High Side-Low Input</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17></TD><TD></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P1391</TD><TD> Glow Plug Circuit Low Input Bank No. 1(Right)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P1392</TD><TD> Glow Plug Circuit High Input (bank1)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P1393</TD><TD> Glow Plug Circuit Low Input Bank No. 2 (Left)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P1394</TD><TD> Glow Plug Circuit High Input (bank2)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P1395</TD><TD> Glow Plug Monitor Fault Bank No. 1</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P1396</TD><TD> Glow Plug Monitor Fault Bank No. 2</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17></TD><TD></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17></TD><TD></TD><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P1399</TD><TD> Glow Plug Circuit High Side-High Input</TD></TR></TBODY></TABLE>
Old Aug 6, 2007 | 04:46 PM
pctjk's Avatar
pctjk
Thanks for all your replies. The code is a 1395. The truck was bought in Nevada.
I use a MAC ET75 Code reader. After further research on this site, I found it is a glow plug monitor fault bank 1. Does this mean to replace glow plugs and GPR? If so any feed back on this job?
Old Aug 17, 2007 | 01:20 PM
pctjk's Avatar
pctjk
Hey Guys, I just finished installing new glow plugs both banks. Started the engine and the service engine light went out. I indeed had worn out glow plugs on the right bank.
I'll change out the GPR later (money issue). Engine seems to start better. This cured the 1395 code. Thanks again for all your help and replies.
Jeff
Old Jan 22, 2008 | 12:11 AM
pepecrower's Avatar
pepecrower
Hi there I am new here pctjk I am about do the same to my father's Truck I wanted to know how difficult was it to replace the glow plugs? What other parts, gaskets etc...do i need for this task? Lastly what is the GPR?? Thanks in advance Pepe
Old Jan 22, 2008 | 03:40 AM
ron's power stroke's Avatar
ron's power stroke
welcome to FTE..
GPR = glow plug relay
this link should help you out..if not..start a new thread and some will help you out..good luck
https://www.ford-trucks.com/forums/4...ke-thread.html
johnsonjf
Jul 12, 2015 11:18 PM
johnsonjf
May 19, 2015 06:02 AM
Jiffy_1
2004 - 2008 F150
Oct 12, 2014 02:23 PM
jeffk813
New Member Introductions
Oct 24, 2013 09:58 PM
koski19
Dec 14, 2012 11:10 AM
