Fuel pump SCREAMING!
Old Aug 6, 2007 | 01:48 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by krscon
I don't want you to think I'm ignoring you - I'm heading to bed - have to get up in 4 hours and hope my truck makes it to work. Thanks for your help/input. If you can think of anything else, I would love to hear about it.
I hear you. Go to bed. We won't fix anything anymore this AM. I still say your problem is in the tank but go to sleep. I am thinking in the pickup assembly, There are a few ways to check this with your extra tank and a length of fuel hose.
Old Aug 6, 2007 | 06:30 AM
kawika's Avatar
kawika
Are there any filters in the tank that you forgot to clean? I believe that in the stock tanks, there a couple.
Old Aug 6, 2007 | 07:31 AM
lancer's Avatar
lancer
I wonder if you have an air leak in the fuel line. If the pump is sucking air it will whine and also make the truck lack in power because of air in the lines. I would replace the feed line from the tank to the pump with a new line and hose clamps. The o-rings in the fuel fitings have been known to leak. I have already done mine to be safe!!! Good luck!!
Old Aug 6, 2007 | 07:34 PM
F350-6's Avatar
F350-6
Before you drop the tank again I'd disconnect the fuel line from the back of the pump and fill a gallon bucket with fuel. Then clamp on a rubber hose to the fuel pump and dip the other end in the bucket. See if that eliminates your noise. If it does work your way backwards, but my guess is a clogged screen in the pick up line inside the tank.
