5.4 Cold Engine Knock
Old Sep 13, 2005 | 03:23 AM
  #151
kylee's Avatar
kylee
Just a note:
Make sure you use the right grade of oil not 15w40 or something like that!!Also some of the after market filters for fords are not the ant-drain back filters like ford uses, I have only seen one after market filter the fram double guard filter that was with the anti-drain back valve in them their regular filters do not have it. This will really hurt your engine without it just something to think about..!!!
Old Sep 22, 2005 | 01:02 AM
  #152
boomer351's Avatar
boomer351
Broken manifold bolts.
Old Nov 26, 2005 | 09:33 AM
  #153
'87BroncoII's Avatar
'87BroncoII
my f250 5.4 no warranty makes that noise lets see how ford likes it when i trade it in for a new one
Old Dec 25, 2005 | 10:27 AM
  #154
turbotuner's Avatar
turbotuner
My 2000 5.4 superduty suffers from the same piston slap when cold. I bought it used with 68000 on it it scares me I make sure its warm before i work it. I now have 129,000 doesn't use oil sill running.
Old Jan 11, 2006 | 07:27 AM
  #155
69_for_fun's Avatar
69_for_fun
So,
What is the oil that you-all recommend to use?
Either dino or synth?
And what grade oil?
Thanks
Macy
Old Jan 11, 2006 | 08:00 AM
  #156
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome 69_fro_fun,to Ford Truck Enthusiasts!
…..See you on the boards.
Old Jan 28, 2006 | 03:17 PM
  #157
DRM2004's Avatar
DRM2004
So this issue has been fixed with the redesigned 2004+ 3V 5.4L's?
Old Jan 28, 2006 | 11:06 PM
  #158
LxMan1's Avatar
LxMan1
Yes, they actually added threads to the head for the 03 2V heads, but the 04-up heads use a totally different plug and have many more threads in the head.
Old Feb 24, 2006 | 08:34 PM
  #159
Lawn Dude's Avatar
Lawn Dude
I have a 98 f250 with a 5.4, and I have the same problem. Took to a ford specialist, and he told me that I have a cracked exhaust manifold. When it first starts up it raps, but after it warms up it stops. In order to fix it I need to get the rusted manifold bolts without snapping them off.
Old Mar 7, 2006 | 10:45 PM
  #160
jethro b's Avatar
jethro b
Well at 245,000 miles mine is still knocking for the first minute or so but always goes away. Guess I'll just have to live with it till 500,000 miles
BTW I use Castrol GTX 10W40
Old Mar 14, 2006 | 09:43 PM
  #161
cankster's Avatar
cankster
I have a 2005 Expedition with the 3V 5.4L motor in it. And I am here checking out why my motor has a cold start knock. LOL. $20,000 miles on it. It appears the 3V motor is not immune.
Lehr
Old Mar 14, 2006 | 10:21 PM
  #162
jethro b's Avatar
jethro b
I'm thinking they only changed the heads and not the lower end. If it were me I'd have them throw in a new crate motor. The knocking may only happen to the original ones. If they won't do that you may be better off leaving your present motor alone instead of having them experiment on yours searching for the cause of the knock. It is basically the design of the piston that is causing the knock. Once the oil pressure comes up it always goes away for me. Good luck with the stealership and keep us updated with your situation.
P.S Have them document the noise and then you'll have paperwork on it if it ever gets worse.
Old May 13, 2006 | 07:12 PM
  #163
panthony's Avatar
panthony
knockin!!!!
My 01 supercrew as well as my 99 had the knock, I was told was normal!!!!
now I have 120k and about paid off!!!! anychance I can get mine replaced?
Old Jun 4, 2006 | 11:10 PM
  #164
3xF150s's Avatar
3xF150s
Thumbs up 5.4L Knock or Tick
My issue was more of a cold start ticking that settled down after the engine warmed up - 2001 SupCrew with 96K. Turned out to be 4 broken exhaust manifold bolts (4of8) on the left side. Now a thrilled owner of a 2006 SupCrew 4WD Long Box. The 3V 5.4 is a great driving motor!
Old Jun 10, 2006 | 06:12 PM
  #165
ed4207's Avatar
ed4207
5.4 Hard Knock
My engine has developed a hard knock over the last 20K miles to the point people turn to watch you go by. Noise seems to come from right front of engine. It doesn't use any oil and has same power as before am thinking about replacing timing chains to see if this helps. Engine doesn't shake and noise will go away at about 1500 RPMs. Will this help? PS engine has 350.000 mile on it. Thanks ED
