too much cam??
Old Aug 4, 2007 | 04:36 PM
Jason8705's Avatar
Jason8705
too much cam??
Hey guys, i got this cam off one of my buds for $25. he was gonna put it in his truck but blew the engine before the got the chance. im thinking about putting it in my stock 302, but idk if id be doing any good putting a cam in as it's still a stock engine. Thanks for yall input
Old Aug 4, 2007 | 05:49 PM
Jason8705's Avatar
Jason8705
I figured this may help...
http://store.summitracing.com/partde...3&autoview=sku
Old Aug 4, 2007 | 11:42 PM
Squiggy's Avatar
Squiggy
Well man thats not too much cam for that engine. a stock HO cam states a .444 lift, so .49 isnt too much, it will idle like a stock 302 because 110 lobe seperation is exactly what a stock cam has. So with more lift, you should be able to gain some horsepower, but dont count on alot. Install new lifters too, they are not hydraulic like the ones you got.
Old Aug 5, 2007 | 11:43 AM
nighthawk285's Avatar
nighthawk285
what year is your truck? if its still running off of a speed density EEC program, that cam wont work because of the 110 lobe seperation....not enough vacuum and it won't idle right.
Old Aug 5, 2007 | 12:43 PM
Jason8705's Avatar
Jason8705
my truck is a 94
Old Aug 5, 2007 | 12:44 PM
nighthawk285
hmmmm, do you know if its MAF? i cant think right at the minute
Old Aug 5, 2007 | 12:49 PM
Jason8705's Avatar
Jason8705
yes it has MAF
Old Aug 5, 2007 | 12:54 PM
nighthawk285
well that should probably be fine then.....yeah thats not too much, heckuva deal for $25. Remember to get new lifters though, yours are hydraulic, but dont re-use lifters, the wear patterns already indented into them will play mean tricks on ya.
Other than that, that oughta be a good cam, I would ask the guys over in the performance section if your engine is a roller cam engine or not since its a '94. Im not sure what year they went to roller cams in the 302s, but if yours is a roller, it might be grinded similar, I dont know
Old Aug 7, 2007 | 11:24 PM
Squiggy's Avatar
Squiggy
Nighthawk is right, for that amount of money its almost better to pull the engine and give it a once over.
Old Aug 7, 2007 | 11:40 PM
Mr. M's Avatar
Mr. M
94 is a roller cam. Looks like he was also a lucky chap with a fabled stock MAF OBD-I California rig.
As stated before... do not re-use you lifters. Purchase the correct and new lifters to break in with your $25 cam.
Old Aug 7, 2007 | 11:51 PM
Navy Jet Mech's Avatar
Navy Jet Mech
Hopefully some further advice isn't unwelcome. If you live in an emissions-concerned state (as I do), make sure it's legal if you want to run it on the street. I'd also be concerned about the cam's incompatibility with computer control. And some more general advice: "If you're undecided between two cams, your best bet would be to pick the smaller one." Good luck!
Old Aug 8, 2007 | 12:26 AM
Jason8705's Avatar
Jason8705
no emission control worries here in tx...where i live anyway. and i only have the one cam so it's not really a choice unless i wanna leave the stock cam in...thanks for all the input guys
Old Aug 8, 2007 | 09:15 AM
Conanski's Avatar
Conanski
Hold on a minute. Your motor should have an F4TE roller cam, and this is a flat tappet cam. You'll need new lifters, longer pushrods, and a different distributor gear for this cam. On top of that, it will probably make the 5.0 even more of a dog at low rpms.. though you may gain a little more upper rpm HP. Your call if you think it's worth the hastle... I don't think it is.. not for that cam.
BTW.. the factory roller lifters are hydraulic just like the flat tappet lifters, the difference being they have a roller tip of course.
Old Aug 8, 2007 | 01:24 PM
Navy Jet Mech
I agree with Conanski. This cam--in my opinion, anyway--is turning out to be way more trouble than it's worth.
