Engine Swap
Old Aug 4, 2007 | 12:58 PM
willfinishrace's Avatar
willfinishrace
Engine Swap
I have an 85 F-150 2wheel drive with a 351 Windsor. I am wanting to replace this engine with a 302 from an 88 Cougar. Can anyone tell me if this is feasible or what the problems are. The 302 has a c4 which i ammnot using . The truck now has a 5 speed stick. I have been told the oil pan might be a problem but don't know. Help!!!!
Old Aug 4, 2007 | 01:29 PM
fordtruckboyf150's Avatar
fordtruckboyf150
you will also need a 302 standard flywheel they have a different balance than a 351
Old Aug 4, 2007 | 02:15 PM
willfinishrace
Thanks for ythe help. I have been told that the oil pans are not interchangeble between a 302 and windsor. Is this true and if not does anybody know if the 302 oil pan will clear the crossover. I am trying to get this settled before I purchase the 302.
Old Aug 4, 2007 | 11:17 PM
nighthawk285's Avatar
nighthawk285
the oil pans should be interchangable. the only difference between a 302 and 351 Windsor (on the bottom end) is the stroke. If anything, the windsor pan will clear better. the 302 pan might clear, but since it was in a car, its probably in a different shape, and will not clear your crossmember.
if anything, look at both pans and their bolt patterns so you know for sure
Old Aug 5, 2007 | 03:39 PM
albung's Avatar
albung
ebay got new pans for both 4 less than 50.00 and pretty sure they r different
Old Aug 5, 2007 | 03:41 PM
nighthawk285
yeah the pans are different shape, but they should have the same bolt pattern where they mate to the block, so they are interchangeable
Old Aug 10, 2007 | 04:09 PM
EPNCSU2006's Avatar
EPNCSU2006
Are you sure? The 351 uses a 3" main journal diameter, while the 302 is a good bit smaller than that. I know the front flanges are the same because timing covers interchange, but is the rear flange the same?
Old Aug 12, 2007 | 04:19 PM
nighthawk285
oooh yeah good point,
