Yes, but good luck getting a set that fits. 1 7/8 IIRC for the fan nut, or a pipe wrench/big cresent wrench ect. I use a strap wrench to hold the pulley. You can try to jamb a screwdriver across the bolts that hold the pulley, watch your knuckles
Hard for me to imagine one coming unscrewed, usually the tough part with the wrenches is breaking the clutch loose from the pump. The rotation of the water pump and drag of the fan should result in the clutch threads being self tightening.
I thought the same thing, I wonder if the clutch was froze up would it unscrew when the engine was shut down? It had to be loose or the engine came to a sudden stop.
How could I tell if the clutch froze? D$mn ford's 1 piece fan shroud.
Mine is a diesel and it was left hand threaded. I have the tools for removing the fan and installing, and I dont need them any more, but it would take a week for them to get to you by mail. Once you have the tools its simple to tighten or loosen. I dont need them cause I went electric. Let me know if I can help. Honestly with out the special tools I dont think I would have ever got mine off. It was tight. You will probebly be okay driving for awhile with out it. I did for a few months and I have heard others doing it for a lot longer. Just dont get stuck in too much traffic. Good luck and just PM your address if you want to get those tools from me.
