Sponsored by: Auxito
Weird AC problem
Old Aug 7, 2002 | 08:28 AM
Yellardawg's Avatar
Yellardawg
Weird AC problem
OK guys,
Sunday night I drove to VA and Monday during the day, used the A/C. It worked fine, but would automatically switch from blowing our of the panel to blowing out of the defroster. I'd turn it off and back on and it'd work most of the times. If it didn't work, I smacked on the controls a little and it'd help.
Tuesday I had no problems with the A/C at all.
Any Ideas????
YD
Old Aug 7, 2002 | 11:53 AM
Superbru's Avatar
Superbru
Weird AC problem
Hey Dawg,
AC blowin out of Defroster usually means a vacuum leak. Defrost position is the "default" position of the vacuum motor that controls where the air will come out. If the vacuum is low, the spring tension on the vacuum motor will return it to the defrost position. Look for a loose or cracked vacuum line. These can be hard to locate, but sometimes can be "heard" if you listen carefully at idle under the dash and under hood.
good luck!
Bru
2002 F150 Super Crew
Black 4X4 Lariat
5.4 Engine Ford Chrome Bars
Ford Bedliner
1979 Bronco 351M 75K orig.
Old Aug 9, 2002 | 08:48 AM
Yellardawg's Avatar
Yellardawg
Weird AC problem
Thanks Bru, IT's worked fine since Monday evening. If it happens again I'll check out the hoses.
YD
Old Aug 9, 2002 | 09:52 AM
odenspike's Avatar
odenspike
Weird AC problem
