F-250 fitting 35's
Old Aug 3, 2007 | 10:57 PM
trailblazr81's Avatar
trailblazr81
F-250 fitting 35's
OK, if all goes well this weekend I'll be picking up a 89 F-250 4x4 extended cab with 5 speed manual. Now I have some almost new low mile 35x12.5 inch tires I would like to run. Right now they are going to waste. So how much lift will it take to fit these tires? Im hoping I can do it with just a 2.5" lift, seeing how thats alot cheaper than a 4". My old neighbor had 35" tires on his early 90's F-350 and I believe it is stock.
Old Aug 4, 2007 | 10:35 AM
roamer37's Avatar
roamer37
They will fit on the rear with out any mods... the front I think you need to space the bumper forward on its brackets to move it out so it will not rub on turns...
Old Aug 4, 2007 | 02:16 PM
Ramblinrich's Avatar
Ramblinrich
I have a 94 2wd that I put 315s under. I had to move the front bumper out 1 1/2 ". They rub on the anti-sway bar at full lock and the fender rubs the outside edgs of the tread under compression. I am looking for a 2" leveling kit to stop the fender rub. I had these same tires on a 86 4wd and the only problem was rubing on the springs at full turn.
Ramblinrich
Old Aug 4, 2007 | 04:05 PM
BIG R's Avatar
BIG R
I would think a 2.5inch lift should be fine. I have a 1985 F350 stock with 315's. I think that is close to a 35inch tire. The only place mine rubbed is the left side front fender,had to do a little cutting on inside of fender, not noticible at all. I have pictures of mine in my gallery if you want to see.
Old Aug 4, 2007 | 04:09 PM
trailblazr81
I always thought the F-350 sat a little bit higher. Maybe I'm wrong. Also can a 12.5" wide tire fit on a stock wheel?
Old Aug 4, 2007 | 05:49 PM
matts156's Avatar
matts156
A 12.5-inch tire won't fit on the factory rim.
My truck has 33s with no lift. That's about as big as I can go without interfering up front. The back tires are not even close to interfering.
Old Aug 4, 2007 | 05:53 PM
BIG R's Avatar
BIG R
The F350 does set higher, thats why I thought the 2.5inch lift would be fine. Don't know if they will fit on a stock rim, my rims are 9" wide. If they are 8" wide, I don't think they will. maybe someone will be along later that can tell you for sure.
Old Aug 4, 2007 | 06:26 PM
trailblazr81
Thanks guys. Guess I'll just get the 2.5" lift and get some cheap steel rims.
Old Aug 6, 2007 | 02:12 PM
Barehuggs's Avatar
Barehuggs
I have a 92 F250 no lift and 33"x12's
No rubbing but no room for more rubber without moving something up front.
No issues in the rear at all.
