Help, my F-250 SD is stuck in 4-low, I've tried turning it off, going forward then backing up and it is still stuck. any suggestions. Truck is 1999 F 250 with Auto trans. Thanks
Crawl under thr truck and unplug the electric motor on the transfer case. Also try rocking it back and forth then going into neutral once it moves in each direction.
that's one reason I wish Ford would have made some kind of manual lever to change modes. For a truck that size it should be mechanical, not electronic - leave that for the soccer mom SUVs.
They do, but unless it was ordered that way, ESOF is what you usually find on dealer lots.
