lowering springs
Old Aug 3, 2007 | 09:23 PM
krazyasslunatic's Avatar
krazyasslunatic
lowering springs
Where can I get them?
Old Aug 6, 2007 | 12:13 AM
J. Frank's Avatar
J. Frank
lmc truck for the front, but i guess you'll have to do a custom job for the rear
Old Aug 6, 2007 | 08:25 AM
FordBoypete's Avatar
FordBoypete
Exclamation
There are no such things as "lowering springs" that work with twin I-Beam steering geometry that I have ever seen, although people will gladly sell you stuff they claim will "work".
FBp
Old Aug 7, 2007 | 10:32 PM
bfgfocus's Avatar
bfgfocus
I have the DJM drop beams on my 68 F100.
Old Aug 8, 2007 | 07:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
J. Frank, if you enjoy FTE, please be aware there are sponsors like BLUE OVAL TRUCK PARTS. MAC's, AUTO-KRAFTERS, and NPD...that sponsor this very forum you are posting in.
Promoting others without mentioning FTE sponsors is unfair.
If FTE didn't have sponsors, there would be no FTE.
lmc is NOT an FTE sponsor.
Old Aug 8, 2007 | 11:29 AM
krazyasslunatic
Do any of the above make lowering springs?
Old Aug 8, 2007 | 01:25 PM
NumberDummy
Find the link ^^^ top of page. Free catalogs for the asking.
But, I've never heard of lowering springs, as FordBoyPete said, you don't want to do this.
The Twin I Beam suspension has to have the correct springs by load rate and vehicle application. Otherwise the geometry will be way off. Just installing stock F250 springs in a F100 will create a nightmare.
Old Aug 8, 2007 | 01:28 PM
ranger69f1's Avatar
ranger69f1
I had a 72 with a 360 and installed springs from a 67 with a 240. The V8 springs are a little stronger. The springs only dropped the front just barely over an inch which gave the look I wanted. With that small of a drop I did'nt have any problems with tire wear or that goofy look of my tires bowing out at the bottom. If you heat, cut, or get shorter springs you WILL have to get the beams bent at an alignment shop. $$$. If you are wanting a 2" or 3" drop, they may not be able to adjust that much out. Better check with a local shop first.
Old Aug 9, 2007 | 01:26 PM
lovejoyjalisco's Avatar
lovejoyjalisco
AIM industries inc. out of mesa,az.( www.truckn-store.com)
