Front end rebuild
Old Aug 3, 2007 | 01:50 PM
robbizkit's Avatar
robbizkit
Front end rebuild
Just looking for advice on where you guys buy your front end rebuild parts. My Xpedition is showing all the tell tale signs that its time.
Also should I be ready to replace the idler arm and pitman arm? Any of you guys need to replace at around 100k?
My X is a 2000 5.4 AWD.
Thanks
Old Aug 3, 2007 | 03:37 PM
buzzard's Avatar
buzzard
I buy all my parts from O'Reilly and I've never replaced a pitman or idler arm on any vehicle I've owned.
Old Aug 3, 2007 | 05:35 PM
MisterCMK's Avatar
MisterCMK
I replaced an idler arm at around 60k on the 2000 Expy. You might look at Rockauto.com for your front end parts.
Old Aug 3, 2007 | 05:46 PM
MisterCMK's Avatar
MisterCMK
Parts for your truck -
2x Spicer upper control arm/ball joint assembly - $38
2x Moog lower ball joints - $29
2x Moog lower control arm bushing kit - $25
1x Moog front sway bar end links (only if yours rusted off) - $7
2x Moog outer tie rod engs - $29
2x Moog inner tie rod ends - $33
Toss in your favorite brand of shocks and there is a front end rebuild. I pulled the prices of each part off of Rockauto.com. It will cost you around $300 to replace everything except the idler arm and the pitman arm.
Old Aug 3, 2007 | 06:56 PM
Modified 99's Avatar
Modified 99
Rock Auto has all you need and shipping is FAST.
Mister CMK forgoy cam bolts to adjust the upper control arms.
Old Aug 3, 2007 | 07:35 PM
MisterCMK's Avatar
MisterCMK
You shouldn't need the cam bolts. The factory bolts should work. IIRC the bolts are under $20 if you end up needing them.
Boba Fett
Jun 29, 2014 04:11 PM
LARIAT 85
Jun 17, 2008 12:57 PM
sm_pacman
1978 - 1996 Big Bronco
Sep 11, 2006 09:30 AM
dcdave
Feb 5, 2006 07:18 PM
maxwgn
Aerostar
16
Oct 9, 2004 09:27 PM
