hey guys, i have a minor problem with my 2004 supercab with towng package.the left blinker on the boat trailer does not work any more . the blinkers on the truck work fine.neither trailer plug(flat or round) have a left blinker and now the local police are doing spot checks. any ideas.I did a test light check on the plugs to confirm its in the truck and not the trailer. thanks--joe
Thanks for the reply.I checked under the hood and found a black plactic box with relays and a 5amp fuse on the side.relays are good,fuse controls both blinkers .I;m still without the left. any more suggestions??I;m ready to try --------- thanks again--joe
Subford is that a 2004 diagram? I only have a 2003 diagram. It shows one fuse feeding two seperate right turn left turn relays. Your diagram shows only two fuses, no relays, unless they are upstream.
In any case, your diagram and mine show the fuses in the under dash fuse box.
Yes it is a 2004 diagram but I was going on memory when I said the fuse was in the engine compartment.
