6.0 stalls
Old Aug 2, 2007 | 05:09 PM
fgc's Avatar
fgc
6.0 stalls
Our 2004 6.0, 4.10 at 70,000 miles is on it's 2nd or 3rd turbo, #1 & 7 injectors replaced, friction modifier added, valve body? replaced,EBP sensor, EGR cooler & valve, fan clutch assembly, replace rear axle clutch packs and still stalled and almost shut down 5 miles from dealership. Ford FSE has looked at it and said the last turbo must be bad. Of course it won't duplicate at dealership and doesn't leave a signature of codes. Does anyone have any ideas? I have had over 25 Fords and currently have 5, but this is geting old.
Old Aug 2, 2007 | 05:58 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
This question should be moved to the 6.0 forum so the resident tecks can help.
Old Aug 2, 2007 | 10:24 PM
toolman05kr's Avatar
toolman05kr
I would have the dealer check the HPOP and the engine wiring harness as these are prone to problems that can cause the condition you have.
Old Aug 2, 2007 | 10:39 PM
UGA33's Avatar
UGA33
check the hpop. Does it start right up and run if you let it set awhile?
Old Aug 3, 2007 | 08:13 AM
fgc's Avatar
fgc
Dec 2006 it was hard to start and sputtered at idle. That's when the injectors were replaced. It seems to start and idle ok. Loaded or not it feels as if it is shuuting down and it doesn't matter if you are on a hill or turning into traffic. Dealer has asked for some piece of test equipment to be sent overnight to them from Ford. When the driver returned to the dealer yesterday after being gone about 10 minutes they drove and drove but could not duplicate.
Old Aug 3, 2007 | 06:21 PM
bravanc's Avatar
bravanc
My truck started to do the same, has it been idling rough for some time? then die? Mine would do that and i would start it right up and continue on. I brought it to the dealer right away so that i would not get stuck somewhere. They cleaned the EGR one time, problem still there. Replaced 2 injectors and tested the fuel system, problem still there. They told me the third time that they could not duplicate the problem so i told them to drive it longer or have someone take it home. Well sure enough on the drive home the quality control rep was able to see the problem. The fix action was they called the hotline for help and ended up replacing the ICP sensor and conector. My truck has not idled rough or died on me yet.
Old Aug 3, 2007 | 10:24 PM
c00nhunterjoe's Avatar
c00nhunterjoe
what year si the truck? this makes a big differene, th e03's had the icp and connector on top the hpop, heat issues melted stuff, late 03's and up had it in the vc, the connectors fell apart. they have crank and cam sensor issues, but an all out stall sounds more like a wire chaffe, check your 3 ficm connectors for rubbing on the vc bolts, follow the main harnes across the top of the intake as it curves under the turbo and across the oil filter and fuel filter and lays on top the intake runners, they are all bad rub points
Old Aug 3, 2007 | 10:25 PM
c00nhunterjoe
sorry 2004 been a long day
Old Aug 7, 2007 | 05:45 PM
fgc's Avatar
fgc
Service Mgr, or writer took truck home this past weekend with a computer hooked up to it. He duplicated the problem 2 or 3 times. They have sent the readings to the FSE, who has, I think sent this information up the ladder. As of today we don't know what the problems are. We'll see.......
Old Aug 7, 2007 | 05:54 PM
c00nhunterjoe
all that means is the tech doesnt know what he's doing, they had the data recorder hooked up and all that does is moniter the pid data for playback after the faulty event, if the tech cant see the problem in that data then you need another dealer
Old Aug 8, 2007 | 08:32 AM
fgc's Avatar
fgc
Probably so, except when the FSE was there with the tech a couple of weeks ago, for about 5 hours he said the turbo they just replaced was bad??? All I want is this truck to perform so my guys will drive it. Can it be fixed is my question?
Old Aug 8, 2007 | 03:49 PM
fgc's Avatar
fgc
FSE said change the VGT, which they did, and I'm still SOL
Old Aug 8, 2007 | 04:34 PM
c00nhunterjoe
vgt will not cause a stall, ever, you can command it with wds, from wide open vane to full closed, it will not stall ever, you need to call customer service and raise hell, that is the only way to get things done at this point, throw the book at 'em
Old Aug 8, 2007 | 05:17 PM
toolman05kr
Just a thought, Has the dealer checked fuel pressure and volume? Had an 05 F350 at the shop today with a stumble, shutdown issue and it wound up being the fuel pump. Had it fixed in 30 minuits.
Old Aug 8, 2007 | 05:34 PM
c00nhunterjoe
you know, for dhas this funny thiing called the diesil diagnostic repair aid, in order to claim a warrenty repair you must have filled it out properly. in order to fill it out you must follow the diagnsotic guidelines in order, if they follow it, the problem will surface, it shouldnt be this hard and you shouldnt be looking for answers here, the truck should have gone to the shop and been diagnosed in less then a day, especially if they were able to duplicate the concern 3 times and get a vehicle data report on it, they are screwing you and you need to call cust service
