Sponsored by: Auxito
A/C turns hot when i accelerate
Old Aug 1, 2007 | 10:00 AM
BrennenS's Avatar
BrennenS
I just bought a 1999 F-150 yesterday and when i was driving it today the A/C turned hot when i accelerated. If i turn it off and then turn it right back on it does the same thing again when i accelerate.
I believe it is my vacuum hose but i dont know where that is on the truck any help or suggestions on what else it might be. If someone could show me a picture of where the hose is would be great too thanks for the help
Old Aug 1, 2007 | 10:15 AM
Big Bad's Avatar
Big Bad
The A/C compressor is disabled under WOT. Under an extended WOT run on a hot day this is normal. If the A/C gets hot under part throttle acceleration you have other problems.
Old Aug 1, 2007 | 10:26 AM
BrennenS's Avatar
BrennenS
Well if i am idleing or maintaining a constant speed i am usually ok it is when i am accelerating normally i hear a faint click "i think" coming from the engine area and it starts to blow hot air even if i stop it does not return to cold it stays hot i have to turn the a/c off and wait a second and then turn it back on and it will blow ice cold until i accelerate.
Old Aug 1, 2007 | 01:33 PM
Joe Finn's Avatar
Joe Finn
If I remember correctly, a vacuum leak will cause this. When you accelerate, you no longer have enough vacuum to keep the blend door in the right position.
Old Aug 1, 2007 | 03:15 PM
Bluegrass 7's Avatar
Bluegrass 7
The click is the compessor clutch dropping out.
I bet the system needs a charge.
The pressure switch on the dryer controls the compressor clutch.
Old Aug 1, 2007 | 10:20 PM
projectSHO89's Avatar
projectSHO89
Busted blend door.
If the clutch were dropping out, the problem would be loss of cooling, not getting HOT.
Vacuum has nothing to do with the temp control.
Old Aug 1, 2007 | 11:00 PM
rshad's Avatar
rshad
Could also be the clutch wear. If you take off the 8mm bolt on the front of the clutch there might be shims (washers) under the clutch face. If so try removing one and see if that helps. This changes the gap in the clutch. Had it happen to my 97 150 and it has been working great now for two years.
You don't even have to take off the belt.
Here is a picture of the breakdown.....
Ron
Old Aug 3, 2007 | 02:22 PM
waimea55's Avatar
waimea55
lots of vehicles shut off the A/C compressor during acceleration; automotive engineers figure you might need the extra power to pass or in an acceleration emergency, like getting around that truck before the next bridge.
Old Aug 3, 2007 | 03:15 PM
projectSHO89
Guys, he said the air was getting HOT, not that the A/C stopped cooling....
That's a difference of several dozen degrees.
If his description is accurate, the blend door is BUSTED. Seen it too many times.
If the clutch were dropping out due to either air gap problems or the WOT was cutting it out, the outlet air would go to outside ambient or so, not HOT.
Have to look at the indicated symptoms. Now, if he exaggerated the description of the symptom, then the clutch would most likely be the problem.
Steve
Old Aug 3, 2007 | 08:32 PM
Wilber15's Avatar
Wilber15
Could be an accumulator comin apart too. We see this in the super duties(infact i just did one yesterday). where the orifice tube gets clogged and the high goes very high and the low side fluctuates fast as the compressor draws a vacuum on the system. you need an ac gauge though.....usually under highway conditions this happens.
Old Aug 3, 2007 | 09:28 PM
Baja FX4's Avatar
Baja FX4
Ive seen this before on a few F150s.
On a really hot day,AC works fine when cruising,but when you step on it.A/C cuts out and air is no longer cold or even warm.Instead you get hot air(Arizona)
3 out of 4 times,it was a coil pack causing a slight misfire under load and PCM disabling A/C compressor.
When you cruise again,A/C is restored.
So my suggestion is,power brake your truck and if you feel even a slight misfire.Then you have found your problem,now all you gotta do is find out which coil pack is misfiring and replace it or the defective boot.
Mike Parker
New Member Introductions
Nov 7, 2015 12:23 AM
kuboy
2004 - 2008 F150
Oct 15, 2012 05:09 AM
pete315
Jun 8, 2010 07:42 AM
r10kidds
27
Sep 29, 2009 04:01 PM
-jeremy
Jul 21, 2005 01:42 PM
