Sponsored by: Auxito
Gas Filter Replacement Set-By-Step
Old Aug 1, 2007 | 09:00 AM
Jim Heritage's Avatar
Jim Heritage
Anybody got a quick Step-By-Step for gas filter replacement? special tools etc..
Thanks,
Jim
Old Aug 1, 2007 | 10:18 AM
KingRanchMan02's Avatar
KingRanchMan02
The fuel line that connects to the fuel filter have quick disconnect lines. There is a spring clip that requires a special tool to release it. This special tool is commonly available at most auto part stores. Push the tool into the connector and then pull on the fuel line. Good luck!
Old Aug 1, 2007 | 10:47 AM
duggyb's Avatar
duggyb
and pull hard...but gentle...mine took about 8 minutes of moving back and forth and around to get off....it can be VERY stubborn!!
just make sure you got the right size tool and go at er!
THNX
Duggy
Old Aug 1, 2007 | 11:17 AM
Jim Heritage
Fuel System Pressure
I read somewhere that you need to relieve the pressure in the fuel system before you remove the filter, is this true and how do you do that.
Thanks,
Jim
Old Aug 1, 2007 | 11:43 AM
mel2000f150's Avatar
mel2000f150
Just let the truck sit for a few hours to lower the pressure in the line.
Old Aug 1, 2007 | 01:52 PM
galaxie641's Avatar
galaxie641
Yes, relieve the pressure, you can simply pull the fuel pump fuse and turn the truck over. There will still be some fuel that spills but it won't squirt out under pressure all over your face at least.
Old Aug 1, 2007 | 02:40 PM
BassMan 32's Avatar
BassMan 32
You might try spraying some penatrating oil in the quick clips as they get lots of what feels like sand or grit in them.
Old Aug 1, 2007 | 04:45 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Nighteyez
N. California Chapter
191
Sep 1, 2014 08:10 AM
Nighteyez
169
Aug 1, 2014 02:00 AM
19jim66
Feb 27, 2008 11:46 AM
Jim Heritage
1997 - 2003 F150
Oct 9, 2007 11:03 PM
Jim Heritage
1997 - 2003 F150
Oct 30, 2006 09:18 PM
