Carb gurus?
Old Mar 24, 2000 | 10:28 AM
chilly460's Avatar
chilly460
Carb gurus?
If any of you have played with holleys a bit and know a thing or two I'd appreciate some help. I'm due to get my 390 back from the shop any day and need to get the carb dialed in before I fire it up. Here's the background: 390 w/Edelbrock aluminum heads, performer RPM intake, .525in lift, 224 degree cam, 9.5:1 compression. I run a '76 F250 (roughly 5500lbs) with 4.10's and 38in. Swampers, and a 4 speed. I just took the engine in for rebuild, it was in the truck before. Problem is, the 750 double pumper on it never allowed it to run just right. I tried different jets and power valves but it always had a big bog under 2300rpm. It also ran a little rich but that's OK, I just didn't jet it down that much, I settled on 73's and 80's. If you all could give me a good baseline jet and power valve setup I'd appreciate it.
Old Mar 26, 2000 | 10:11 AM
Phillip Guidry's Avatar
Phillip Guidry
Carb gurus?
In my opinion, you should go to a vacuum secondary carb,and leave the double pumper for an all out mud racing weekend kinda thing. It is very hard to dial in a double pumper unless you have asome hard core info from a dyno test for a set up just like yours.Just to give you an idea on how carb tuning is delicate , pick up the latest issue of Car Craft (April) and there is an article(based on a chevy) on dialing in a carb to a stock exhaust,and then after adding headers and duals, having to re-dial the carb in . Very interesting the way the jet sizes changed in order to produce peak levels.
Phillip
Old Mar 28, 2000 | 08:25 AM
Motorcraftsman's Avatar
Motorcraftsman
Carb gurus?
Classicdriver
65
Feb 14, 2017 08:45 PM
Guhfluh
Jan 9, 2017 05:35 PM
5 Star Tuning
Vendor Specials, Discounts, Product Announcements & Group Buys
Aug 21, 2015 11:50 AM
WilliamKG88
Jun 18, 2015 05:24 PM
matt77F2504x4
37
Sep 21, 2004 03:15 PM
