View Poll Results: Options
I have no idea?
0%
Replace Carb.
0%
Put a 4bbl intake in it.
0%
Other.
100.00%
Voters: 1. You may not vote on this poll
Engine Runs Bad.
Old Aug 1, 2007 | 07:52 AM
truckman15's Avatar
truckman15
Engine Runs Bad.
I have a 1981 Ford F100 with a 300 six engine. Compression is ok. I have new plugs and wires and the igntion system is fine. I've had THREE kits in the carter yfa carb. Today it runs bad and i have to kepp my foot on the gas to keep it from stalling. What should i Do? I'm thinking of puting a carter yf base carb in it, good idea?
Old Aug 1, 2007 | 11:38 AM
Franklin2's Avatar
Franklin2
Look for vacuum leaks. Take the egr valve off and make a block off gasket to see if it's leaking.
Old Aug 1, 2007 | 11:29 PM
johnsnewtruck's Avatar
johnsnewtruck
what happens when you adjust the af screw or the idle screw also how does it run otherwise?
