When do these trucks start giving problems?
Old Jul 31, 2007 | 10:13 PM
61 uni's Avatar
61 uni
Does it usually happen at 150K+, 200K+ or just due to age? My truck only has 117K on it and it runs great. I hear about high pressure pumps and injectors going bad and a couple of other things that cause injectors from working properly, glow plugs ect. I wonder about taking the truck on trips sometimes. I don't to be stuck wrenching in the middle of nowhere.
Old Jul 31, 2007 | 10:21 PM
wreckit72's Avatar
wreckit72
They start giving people problems when they start neglecting the maintenance. You should be able to go 250000 miles on the original injectors if you keep up on the oil changes. You may get less though when you catch PMS.
Old Jul 31, 2007 | 11:03 PM
10bands's Avatar
10bands
GIVING PROBLEMS! NEVER! Shame on you for thinking that. They just need the occasional upgrade or modification.
Seriously though I don't think you can really put a number to any of it. There's guys here with over 300,000 that claim they haven't had anything serious go wrong. They probably never miss a fluid or filter change either.
O-rings seem to be a common problem with high mileage. Injectors, IDM, turbo pedestal and various other parts(don't forget the CCV) will eventually need orings. I kind of have a thing about orings though. When somebody posts about a bad oring that I haven't dealt with yet I usually have to replace mine too.
Old Jul 31, 2007 | 11:09 PM
wreckit72's Avatar
wreckit72
I meant to say that you may not get 250000 miles on your injectors when you catch PMS because you may want to get larger injectors.
Old Jul 31, 2007 | 11:45 PM
Zookie400's Avatar
Zookie400
these truck previously were bulletproof, but ever since we switched over to ULSD i have been replacing one by one all of my fuel system pieces....first the pump went, i didnt have a chance to fix that before the hoses all started weepinig, then an injector. all of these within the first 3 months of the big changeover from LSD.
other than that, just a starter,alternator, and vac. pump. i am currently at 180,000 miles.
Old Aug 1, 2007 | 12:51 AM
johnstoys2's Avatar
johnstoys2
I bought my truck at 236 K. a year ago next week. the only thing I had to fix so far was a stuck e- brake cable & a rear wheel seal. It just keeps going.
Old Aug 1, 2007 | 06:09 AM
F0rdF0rever's Avatar
F0rdF0rever
Heres a list of parts ive replaced between 200k and now, 250k:
Vacuum pump
idler pully
alternator
blower motor
blower motor resistor
power steering pump
master cylinder
brake booster
abs valve
hpop
fuel pump
fuel heater
injectors needed rebuild
transmission e4od
transfer case
fuel level sender
Thats the stuff I can think of off the top of my head.
