10 K Mod
Old Jul 31, 2007 | 10:06 PM
Justin Time's Avatar
Justin Time
10 K Mod
Wow! Just finished the 10 K mod on my 96 PSD with 205,000 miles. I can't believe the difference in performance. Seems like it has added 50 HP and 40% more low in torque. Took me about 10 minutes on the outside and cost $1.00 for a 6 pack of resistors.
Thanks to all for your postings on how to do the 10K mod. Great site!
Justin
Old Jul 31, 2007 | 10:17 PM
Neal 97 250's Avatar
Neal 97 250
Great mod huh? try 6K after you add a pyrometer. I am planning this one.
Old Jul 31, 2007 | 10:42 PM
powerstroked162's Avatar
powerstroked162
Try a chip...... lol
Cowboy Steve
Old Aug 1, 2007 | 12:47 AM
Flea's Avatar
Flea
Can I do the 10k mod safely now.
I have just added a 3" dp and a the trucool max.
I don't have a pyro or tranny gauges.
What do you all think?
I am saving up for gauges.
Old Aug 1, 2007 | 06:25 AM
Neal 97 250
Yes you can it is safe especially if you don't do alot of heavy pulling up hills. I did mine before gauges and when I put them in the temps are close but not too hot. Remember don't pull over 5-6000lbs. up hill for 10 miles and you will be fine.
Old Aug 1, 2007 | 07:36 AM
Justin Time
Unhappy
Didn’t know the towing limitations with the mod. I pull a 12,000 pound fifth wheel often. I guess I will need to remove the mod before towing. I was looking forward to the added HP and torque.
Justin
Old Aug 1, 2007 | 07:44 AM
Neal 97 250
If you are not towing extreme, ie: up hill bothways and at a high rate of speed you might be fine. I just pulled a Maxima and gooseneck trailer across NC the long way mountains and all and My after turbo temp got to 900-950 at times. That means the pre turbo was "probably" close to or at 1200 degrees and that is the max I would go. Although it only did that in the mountains and when I was passing up hill. I estimate the weight I was pulling to be around 5000 or a bit more.
Old Aug 1, 2007 | 10:39 AM
MagKarl's Avatar
MagKarl
Does a good chip like TW or DP make the 10K pointless, or is there benefit to having both? I haven't bothered with the 10K yet because I am getting a chip. Wrong assumption?
Old Aug 1, 2007 | 11:06 AM
Neal 97 250
That is a good question that i do not know the answer to. I do see people here that run the 10K with a chip or programmer and I see others who do not. I imagine it depends on which chip you have. I would ask Tony or DP to be sure.
Old Aug 1, 2007 | 11:58 AM
powerstroked162
Alot of people say that it is a pointless mod with a Dp or Ts chip as the tunes already cover that area inwhich the 10k mod tweaks. I personally run them stacked and I think I can tell a difference. I have yet to dyno it with it stacked and without to see if there is a diffrence. I'll be sure to post up what I find
Cowboy Steve
Old Aug 1, 2007 | 12:17 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Ditto what Cowboy Steve said, I talked once with TW and he told me that the 10K mod has to be removed when you install a chip.
Old Aug 1, 2007 | 12:18 PM
Neal 97 250
I have often wondered what TW's take on that was. Thanks roentgeep
Old Aug 1, 2007 | 12:23 PM
Justin Time
Hey Neal,
I am from Charleston, SC and I am familar with the beautiful NC mountains. Sounds like I need to install a temp gauge for the turbo and tranny do you know of any links for instructions on "How to" install theses gauges?
Thanks,
Justin
Old Aug 1, 2007 | 12:26 PM
Neal 97 250
Yes I do but I am not using my compute right now I am on a secure one and doesn't have my fav's on it If nobody else gives you one I will try to find it later tonight. In the meantime I will try google. b-back shortly
Old Aug 1, 2007 | 12:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Originally Posted by Justin Time
Hey Neal,
Thanks,
Justin
Check this links:
http://www.smokyvalley.com/gauge_install.htm
http://www.dieselmanor.com/installsheets.asp
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
