95 lightning
95 lightning
Hello i purchased a 1995 lightning this weekend and i have some qusetions. did it come from the factory with a roller cam, or a hyd cam? and does anyone have any sugestions as to what cam would be a nice streetable upgrade? it is a 1995 with 37K miles! mass air conversion, equal length Bassani headers and exhaust, with 30 pound injs. it runs great, but would like alittle more. thank you for your help.
The GEN 1's didn't come with roller cams from the factory. However, most can be converted easily and it's relatively inexpensive if you use Ford hardware.
The F-cam is going to be a bit much for a pickup with a stock converter. Best option would be to go with a custom grind cam. However, quite a few owners have noticed a mild improvement with a Mustang roller cam swap (87-93 5.0 HO). Those cams in a GEN 1 Lightning seem to idle well and pull nice at higher RPM's, where the stock cam would start to fall off.
Heesman
08-27-2013 06:39 PM
Rockaholic
15
02-20-2012 03:20 PM
broncobillybob
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
03-23-2005 11:40 PM
hockeyleg95
12-21-2002 06:14 PM
