95 lightning - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
95 lightning
Old 08-13-2007, 11:10 PM
Dr.B
Dr.B is offline
Dr.B is starting off with a positive reputation.
Talking 95 lightning
Hello i purchased a 1995 lightning this weekend and i have some qusetions. did it come from the factory with a roller cam, or a hyd cam? and does anyone have any sugestions as to what cam would be a nice streetable upgrade? it is a 1995 with 37K miles! mass air conversion, equal length Bassani headers and exhaust, with 30 pound injs. it runs great, but would like alittle more. thank you for your help.
Old 08-14-2007, 02:06 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
If it's a roller, I would think the FRPP F303 would be a good cam. Not sure how it will like a stock torque converter though. I've never heard one, but want one for my Mustang.
Old 08-14-2007, 07:34 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Blurry94 has a great reputation on FTE.Blurry94 has a great reputation on FTE.Blurry94 has a great reputation on FTE.Blurry94 has a great reputation on FTE.
The GEN 1's didn't come with roller cams from the factory. However, most can be converted easily and it's relatively inexpensive if you use Ford hardware.
The F-cam is going to be a bit much for a pickup with a stock converter. Best option would be to go with a custom grind cam. However, quite a few owners have noticed a mild improvement with a Mustang roller cam swap (87-93 5.0 HO). Those cams in a GEN 1 Lightning seem to idle well and pull nice at higher RPM's, where the stock cam would start to fall off.
Old 08-16-2007, 10:57 PM
Charlie41
Charlie41 is offline
Charlie41 is starting off with a positive reputation.
If it has had the mass air conversion, you can run the f cam. But you may not like it. No so good street manners.
Blurry94 has it right with getting a custom grind.
Charlie
Old 09-02-2007, 01:56 PM
lightning94
lightning94 is offline
lightning94 is starting off with a positive reputation.
i have a 94 just pulled it down this weekend it has a hyd flat tappet going to b-303 roller have mass air. bassani headers flowmasters got to find pushrod length before i can go any farther everyone tells me i will like the cam will let you know how it works dave
Old 09-03-2007, 01:37 PM
fast83
fast83 is offline
fast83 is starting off with a positive reputation.
so the cams for 351W will fit a 302 block I have had real good luck with a 292H cam from comp cams
Heesman
08-27-2013 07:39 PM
Rockaholic
15
02-20-2012 04:20 PM
broncobillybob
03-24-2005 12:40 AM
hockeyleg95
12-21-2002 07:14 PM
302man
02-13-2002 07:06 PM
Quick Reply: 95 lightning
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
