trans drip
Old Jul 31, 2007 | 04:28 PM
hdman6's Avatar
hdman6
Question trans drip
I installed my mods last feb, I removed the tranny pan, reused the same gasket wiped it all clean etc. Then after the vb install i reinstalled everything and torqued it to the specs (tranny pan screws) now im getting a drinning from say the middle of the pan back and all the tranny screws have a little drip on them. It looks like the rubber gasket is seeping. You think just a little wrench on each screw will do the trick? I dont want to overtighten it since it is aluminum, or is a new gasket maybe in order since it was torqued to specs.. Jeff
Old Jul 31, 2007 | 05:18 PM
ernesteugene's Avatar
ernesteugene
I never try to reuse gaskets for this reason, even though the manual says it's ok to do so. I had a Ford dealer strip one of my pan bolts, so definitely don't over tighten them trying to fix the leak that way. Fortunately, the bolt that stripped was on a section of the case flange that allowed the use of a undersized bolt with a nut on the top of the flange. BTW, the dealer tried to hide their screw up, but when I got back to my RV park I applied gentle torque to all the bolts to make sure all were tight, and the stripped one was as loose as a goose and I could spin it with my fingers!
pawpaw
1983 - 2012 Ranger & B-Series
17
Apr 26, 2014 08:52 PM
r___r
Dec 15, 2013 06:11 PM
Oppland
Feb 20, 2011 09:30 AM
FordmanShane
Sep 18, 2010 06:22 AM
wagonerkl
Bronco II
Jun 12, 2010 01:06 PM
