indepth questions
Old Jul 31, 2007 | 03:25 PM
marine009's Avatar
marine009
indepth questions
hey i have a 85 f150 with a streight 6 300 thats been bored 60 over with clifford intake and a holley 650 cfm the truck was origanaly a stick shift truck but i changed it to an automatic i am i think the gearing is 3.00.1 the truck has great power but will not spin the wheels if i stomp it to the floor even if i but it in 1st and shift it manualy into d what could be the problem any help thanks
Old Jul 31, 2007 | 04:12 PM
rbloodhound's Avatar
rbloodhound
Sounds to me that it is geared to high.
Old Jul 31, 2007 | 04:18 PM
marine009's Avatar
marine009
indepth question
bloodhound thanks for the reply do you think i should go to 3.77.1 or what cause i figured with the truck and engine it should spin the tire prety good on the highway i can run 65 with half a pedal and can stomp it and it will kick ya back in the seat and if i get in it early in the mornin befor it gets real hot outside and stomp it to the floor it will get second gear very small but will get it any suggestions
Old Jul 31, 2007 | 04:21 PM
rbloodhound
Does it loose power when it warms up?
Old Jul 31, 2007 | 04:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
On the Warranty (VIN) Plate on the door, you will find the AXLE code. You can decode it using the FTE axle decoder, or post it here.
Old Jul 31, 2007 | 04:49 PM
marine009's Avatar
marine009
rbloodhouns no it doesnt loose power when hot just gets wheel in second on a cooler day but just not sure why it will not roast the tires so to speek with the engine set up the engine was repuilt 3 years ago new rod rod bearings the works was done very well just cant figure this problem out almost seems like the carb is loading up but i take the sparke plugs out and they arent wet and are just a lil tan starts right up like a new truck and runs great other than this problem
Old Jul 31, 2007 | 04:53 PM
marine009's Avatar
marine009
numberdummy the axel code is 18 thanks for the help
Old Aug 1, 2007 | 12:23 AM
NumberDummy
Welcome to FTE
18 = Ford 9 Inch Rear Axle / 3.08-1 / non Limited Slip / 3,750 lb. Rear Axle Capacity
Old Aug 1, 2007 | 11:38 AM
marine009's Avatar
marine009
hey man i apreciate the info i found a web site that gives most of the codes and all from the dood jam sticker but it didnt tell the rearend size i researched online and it said most ford trucks that year came with 8.8 rearend bot doubting you just double checking cause im now looking for a used set of 3.77 3.89 or around there gears for my truck and dont want to buy them and not be able to use them but i do realy apreciate the help thanks
Old Aug 1, 2007 | 01:25 PM
NumberDummy
Oops...it could be either a 8.8 or a 9 inch. The 9 inch rear axle was available till 1987, the 8.8 was introduced in 1983. I've decoded 100's of axle codes on FTE, but most are pre 1980. When I saw "Ford" rear end in the axle decoder in the Ford truck parts catalog, I typed 9 inch out of habit.
It's easy to tell which rear axle you have. If it has a removable cover on the back side, it's an 8.8. No cover = 9 inch.
Old Aug 1, 2007 | 02:17 PM
JMardis's Avatar
JMardis
The time you waste spinning tires makes it easier for the guy to get a holeshot on ya.I had a 81 f100 swb with a mildly built 460,c6 and 3.25 traction loc and she would not spin for anything except wet pavement.
Old Aug 1, 2007 | 03:35 PM
marine009's Avatar
marine009
hey bud its def a 8.8 got on line and found out what you just said about the back plate coming off and it does now to find someone with a set of gears for it i got a friend that has a set of pos trac 3.73 comp with all washers eerything and he said for 350 he would sell me the set and put it in he ownes a performance place here in lexington so i may do that but thanks for the info
