Sponsored by: Auxito
Rear-end squeak/clunk
Old Jul 31, 2007 | 03:04 PM
KingScott's Avatar
KingScott
Question Rear-end squeak/clunk
I hate squeaks and rattles, and so far my 2003 4x4 SCrew has been alright until recently.
First, I have noticed a squeaking/chirping sound coming from the rear driver's side. It seems to occur at all speeds, and especially when going down bumpy roads. Braking seems to diminish the noise a little. Went underneath with a rubber mallet and started tapping on stuff to replicate the sound. No luck on the big squeak, but I did fix a small squeak on the e-brake line/linkage (the main squeak continues). It's hard to describe...any thoughts from someone cursed with the same problem?
Second, and it may be linked to the same problem, but I often get this clunking sound from the rear end as I am pulling into a parking spot or something when I tap the brakes. It does not affect the braking, it just sounds like someone is banging on a hollow pipe with a small hammer.
It's easier to ask than go through the postings. Word.
Old Jul 31, 2007 | 03:34 PM
okgearhead's Avatar
okgearhead
The first one sounds like the rear brakes, the warning tab could be scraping the rotor making the squeaks. The second one sounds like maybe a u-joint starting to go. good-luck!!!
Old Jul 31, 2007 | 05:15 PM
KingScott's Avatar
KingScott
Okay, cool. I'll go ahead and pull the brakes and check the u-joints. Thanks for the help...
Old Jul 31, 2007 | 08:19 PM
dendeanda's Avatar
dendeanda
Chirping when you hit bumps could be your rear shocks. This happened to my front ones then it stopped after a while. Then the rear ones started doing it. I reckon it will stop soon. Check your tailgate too.
Old Aug 1, 2007 | 09:38 AM
KingScott's Avatar
KingScott
I'll go ahead and check the shocks...don't know if I can wait for it to go away though. Thanks for the tip, and I'll check the tailgate as well. I have a feeling the brakes may have something to do with it because I tugged on the e-brake cable, and noticed the linkage arm that connects the cable to the brake housing seemed to have play in it on both sides, and it was making a tapping noise as I moved it back and forth.
Old Aug 26, 2007 | 09:27 AM
Polyb's Avatar
Polyb
Holy crap I thought I may have been the only one with this problem in my 03 supercrew. The squeak I hear is like a rotatioal thing...I roll the truck forward its slow I tramp on it its way louder and embarassing. I have had 2 friends tell me they think its a ujoint going bad so Im buying a pair also I noticed the rearend seal is weeping so when the shaft is out I replace that too. I did have the shock squeak over speed bumps but it has since stopped. After reading some of the replies you got I will be popping off the back brakes too. The clunk you talk about do you turn off the overdrive when you just bombing around town I heard you shouldnt have it on if you truckin around at less than 80km/hr (yes Im in Canada) I notice if I forget to turn it off I sometimes get a little thump when cruising at lower speeds. Ill be back to look at this post a little more often to see how your making out good luck I know I cant stand the noise anymore!!
Old Aug 26, 2007 | 03:44 PM
deo59's Avatar
deo59
I have a 2001 F-150 scab. The u-joints went dry after 70k and made the sqeak you describe. They were tough to remove, had to heat them and pound on them. There was not a drop of grease for at least 10 miles in any direction of them!!! The rear was really bad.
Good luck.
Old Aug 27, 2007 | 07:09 AM
steelers06steelers's Avatar
steelers06steelers
I have a 2002 s-cab, my ujoints went at about 85,000 miles, that was the squeek.
I also get a clunk/rattle over bumps, sounds like it is in the rear end, I will check the shocks.
I also get a strange growling noise from the rear disk brakes when I apply with some force. It doesnt do it with light application, only when I press hard. anyone else????
some people have suggested pads and hardware, they have been replaced...
Old Aug 27, 2007 | 08:28 PM
deo59's Avatar
deo59
For the clunk/rattle check the u-bolts holding the leafs to the axle. For the brakes, check the emergency drum brakes inside the read discs. They are a pain in the butt! On mine the cable came off the right pawl and the whole assembly was a wreck when I opened it up.
HighRiskJob
1997 - 2003 F150
Sep 16, 2014 09:22 AM
PatrickNDT
Jul 23, 2014 09:53 AM
Strokt350d
6.2L V8
Jul 2, 2014 06:53 AM
AkF250HD
Aug 7, 2013 06:31 PM
maxtruck00
May 22, 2009 12:52 PM
