Blower switch
Old Jul 31, 2007 | 08:07 AM
crabster's Avatar
crabster
Blower switch
Hi guys,
The blower in my wifes 99 expedition stopped working on lo-med, worked only on high. So I replaced the blower motor resistor and nothing happens. She now tells me that right before I replaced the high setting stopped working so I'm now thinking the switch might have went bad too. Can someone tell me if replacing the switch is an esy project, where it is located, dows the dash have to be taken apart? Might have to farm this project out. Thanks!
I should add that the expy had front and rear hvac. The back works fine, it;s just the front fan that does not work. Thanks!
Old Jul 31, 2007 | 09:49 AM
04markIII's Avatar
04markIII
did you check to make sure the connector the the resistor wasnt burnt? should be relativly easy to change out. according to the pic in my system, pull off the center bezel(large) and then unbolt the hvac head unit. unplug the old switch, install new switch, and put back together.
Old Aug 20, 2007 | 11:00 AM
APS612's Avatar
APS612
I am having the same issue as Crabster above. Just replaced the dash fan speed switch (it was real easy) but, it did not resolve the issue. Checked every fuse on both fuse boxes. I still have only the highest fan speed working. On a long trip that gets really irritating. Anyone have any other ideas?
Old Aug 20, 2007 | 01:58 PM
04markIII's Avatar
04markIII
sounds like your issue is the resistor...not the switch.
Old Aug 21, 2007 | 06:55 AM
projectSHO89's Avatar
projectSHO89
Yep. High speed only is a standard failure mode of the resistor pack.
Steve
Old Aug 21, 2007 | 08:49 AM
APS612's Avatar
APS612
I found it up under the dash and pulled it out last night. The thing looks in horrible shape with corrosion. I will try to locate a new one today. Let ya know if it resolves the issue. Thanks for the help.
Old Sep 1, 2007 | 07:33 AM
myblkexpy's Avatar
myblkexpy
I have the same problem on my 99. Fan only works on high. What is a resistor pack and where can I find it?
APS612, Did you find one? Where and how much was it?
Old Sep 1, 2007 | 08:11 AM
APS612's Avatar
APS612
I purchased it from the local Ford dealer for about $16. Make sure you take the old one with you. I was initally handed the wrong switch as others on here have noted. So save yourself possible return trip. Take the old one and compare. It took me about 20 mins to take it out and less than 5 mins to put it back in.
Old Sep 12, 2007 | 04:27 PM
Dre82s's Avatar
Dre82s
I pull the wire harness from my relay under the dash and I found to have extensive corrosion as well as one one of the connectors had shorted out and damaged the harness it has a connector on both ends of the wire but dealership is quoted me $75 for maybe a foot worth of wires and and a relay... looking at junk yards for the wires. even when disconnect disconnected from the relay blower still works on high!
jtcdudeman
Sep 16, 2016 01:05 PM
dockwatson
Mar 12, 2014 08:42 AM
apollo95
1983 - 2012 Ranger & B-Series
Oct 10, 2006 12:31 PM
5jordan
Aug 5, 2004 10:29 PM
fordblue_ca
Nov 7, 2003 02:41 PM
