I've only had 1 302 and at 108k miles it threw 2 rods split the piston housing on the block and cracked a piston, engine was stock with an all forged rotating assembly
cyl 1 rod to piston broken
no rod mode
not connected
rod went byebye
good pic of the snapped rod
rod broken from crank
heres cylinder 8s broken rod
heres the other end still connected
pieces
i tried to clean it up best i could
pic of the hole in the oil pan (engine removed for clarity lol)
In 302 rods, the C8OE's are good to 7500 rpms with ARP bolts. Beware of the 90's rod, I think the forging numbers are F1TE, I've seen a couple of stock applications that broke these. Some of the stock forgings are better than others. Others to stay away from are the old 352/360 FE rods, lay one next to a 390 rod and you'll see the difference.
