oil pressure????
Old Jul 30, 2007 | 11:58 PM
Ford_250's Avatar
Ford_250
oil pressure????
So i just got done installing my new timing gear on my 88. I primed the pump for a minute or so. Turned the key and it popped right off. Problem is, no oil pressure. kept running nothing sounded terrible then all of a sudden my lifters started rattling. i looked in the oil fill hole and i could see there was no oil upstairs. So im a little perplexed to say the least. I installed a new oil pump. the only thing i can possibly think is a blockage somewhere from bits of where my old cam broke (Fiber Composite, thank you engineers) or the oil sump's arm that connect to the mains was broke, would that let the sump suck down on the oil pan? i guess ill pull the oil pan off, which by the way is very exciting with the engine in the truck, never had done that before so that was a nice new trick i learned off of FTE. So if anybody much older and wiser has a idea let me know. Thanks
Old Aug 1, 2007 | 04:28 PM
classicranger's Avatar
classicranger
Did you install the shaft back into the bottom of the distributor?
Mr. Ed
Nov 8, 2016 10:00 AM
axelgawn
Jan 1, 2016 07:06 AM
motocrossross
Nov 4, 2014 08:39 AM
DirtyCustoms
Mar 19, 2012 01:18 PM
302junkie
Engine Swaps
Apr 26, 2011 07:54 AM
