Intermittent dying
Old Jul 30, 2007 | 10:24 PM
bdjupiter's Avatar
bdjupiter
Intermittent dying
This question is for a friend of mine that just purchased a 96 F250 with the 7.3L. The truck starts fine but will intermittently die, sometimes it will be at idle, other times as it's going down the road. It restarts just fine and will go for a couple of days and then it will do the same thing. I was wondering if you all had any ideas. To add to the twist and I personally think these are two separate issues he has a brake controller on the truck and when he engages it to activate the trailer brakes it kills the truck. I figured if anyone would know it would be you all so please help me out. Thanks.
Old Jul 30, 2007 | 10:47 PM
Neal 97 250's Avatar
Neal 97 250
Not sure about the brakes but it sounds like a cam position sensor check here.
http://catalog.powerstrokeshop.com/p...catalogid=3660
Old Jul 31, 2007 | 04:06 AM
powerstroked162's Avatar
powerstroked162
Ok well, its sounds like your friend has a bad CPS and as for the brake controller issue, was it wired in or did you guys use the factory harness and port? If its hard wired in, you need to check the wiring over again for a ground out issue. Post what you find. Good luck!
Cowboy Steve
Old Jul 31, 2007 | 04:56 AM
trike1946's Avatar
trike1946
I vote with both . CPS and a ground issue on the controller.
Old Jul 31, 2007 | 07:17 AM
tjbeggs's Avatar
tjbeggs
I vote its just needs a CPS. I have heard a number of CPS issue that are random and when the trailer brakes are used. Replace the CPS with the one that Neal linked then see where you stand.
Old Jul 31, 2007 | 07:47 AM
bdjupiter's Avatar
bdjupiter
Thanks guys, I appreciate it. I will tell him about the CPS and then have him check the wiring on the brake controller.
Old Jul 31, 2007 | 11:11 AM
Neal 97 250
Good luck and keep us posted of the results. See, we thrive on this kinda stuff.
Old Jul 31, 2007 | 09:57 PM
slowtrucks's Avatar
slowtrucks
Probably the CPS, Mine did the same thing. I repalced it and now it works great.
Old Jul 31, 2007 | 10:00 PM
powerstroked162
Make sure you get the cheap CPS and not the $80 counter part.
Cowboy Steve
Old Jul 31, 2007 | 10:09 PM
Neal 97 250
The dealer may be cheaper than was thought but tell them you want a 99-03 CPS it is the same but cheaper.
slowtrucks's Avatar
slowtrucks
What is the Cheap CPS? I think I want to get one to keep in the truck.
Old Jul 31, 2007 | 10:11 PM
powerstroked162
Cowboy Steve
wreckit72's Avatar
wreckit72
This one. http://catalog.powerstrokeshop.com/p...catalogid=3660
Old Jul 31, 2007 | 10:25 PM
Neal 97 250
[QUOTE=wreckit72]This one. http://catalog.powerstrokeshop.com/partlocator/index.cfm?action=MorePartInfo&PartID=287257&siteid =214083&catalogid=3660[/QUOTE]
ditto. that is it.
Old Jul 31, 2007 | 10:26 PM
Neal 97 250
Originally Posted by powerstroked162
Cowboy Steve
Whazzup did you hiccup?????????
