Sponsored by: Auxito
A/C question
Old Jul 30, 2007 | 01:33 PM
JOE SKI's Avatar
JOE SKI
A/C question
my fan blows cold air whether its on the A/C side of the selector switch or the fan side. The temp switch is set all the way to cold and the panel/vent ducts are selected on my '97 flareside. Any ideas on what's wrong?
Old Jul 30, 2007 | 01:35 PM
KingRanchMan02's Avatar
KingRanchMan02
Broken blend door?
Old Jul 30, 2007 | 08:39 PM
steve(ill)'s Avatar
steve(ill)
the HOT-COLD adjustment **** changes the temp by mixing air from the AC with air from the heater to get teh correct temp. when the AC button is off, the temp is a combination of outside air and heater core air. as KR said, there is a "door" that is electrically controlled by a small motor. it is possible the arm between the blend door and the motor is broke. lay on the floor and look above the throttle pedal and turn the **** from hot to cold and see if you can see the motor or arm moving.
Old Jul 31, 2007 | 05:51 AM
projectSHO89's Avatar
projectSHO89
Also, check the temperature control for the common stripped ****.
Steve
Old Jul 31, 2007 | 08:04 AM
JOE SKI's Avatar
JOE SKI
what is the common stripped ****? will check the blend door...thanks everyone
Old Jul 31, 2007 | 08:29 AM
projectSHO89
Pull the TEMP **** off and inspect it. They split and strip, causing the **** to slip on the shaft.
Steve
