runs rough and rich
Old Jul 29, 2007 | 07:49 PM
roughrunner96's Avatar
roughrunner96
Question runs rough and rich
I have a 1996 F-250 that runs rough and rich. Seems to be getting worse everyday. Did tuneup and tested some suspect sensors to no avail. Check engine light has never came on. Blows black smoke and soot out the tailpipe and wants to stall when starting out from a stop. Any suggestions of where to start checking would be appreciated. Thks.
Old Jul 29, 2007 | 07:53 PM
andym's Avatar
andym
Pull the codes. Just because the light never came on doesn't mean there aren't codes present.
It would also help to know something about the truck... engine, transmission would be a good start.
Old Jul 29, 2007 | 09:53 PM
roughrunner96
Red face runs rough and rich
Sorry about that, I thought I put the engine in there. Its a 5.8 liter with 5 speed manual. My chiltons says that starting in '96 you need a scan tool to retrieve codes on f series trucks. is that true?
Old Jul 29, 2007 | 10:01 PM
roughrunner96
Im new. sorry about that. Its a 5.8 liter 5 speed manual. My first post had that info but I erased it somehow.
Old Jul 29, 2007 | 10:29 PM
handyman43358's Avatar
handyman43358
Check the fuel pressure. I bet the fuel pressure regulator is bad. You should have around 40 PSI at idle. You could also pull the vaccuum line off of it and see if theres fuel in the line. That also indicates a bad one. Let Subford read this and he'll post pictures of what you need and where it's at, because he is a God like that!
Old Jul 29, 2007 | 10:36 PM
roughrunner96
Thks. that seems like a popular thing to check from what i've been reading. Ill check it out in the morn and see if i have to find a steep cliff to drift her down. LOL.
Old Jul 30, 2007 | 04:36 PM
handyman43358
Haha! If you're going to do that, bring it to my house and push it down the driveway into my garage.
Old Jul 30, 2007 | 04:52 PM
meatloaf87's Avatar
meatloaf87
is there any restriction in the exhaust you might have a cloged cat
Old Jul 30, 2007 | 04:58 PM
handyman43358
A restriction in the exhaust most likely would not cause it to run rich and blow black smoke. If anything, it would keep it from doing that. Not only that, but it stalls on him when hes at a stop, which the truck is at lower RPM's, and not able to burn all the fuel. If he was having trouble at high speeds with the RPM's high, I could see it, but not here.
Old Aug 2, 2007 | 01:16 PM
roughrunner96
Smile rough and rich
checked the fuel pressure and found it to be 85 lbs! Installed a new regulator and it runs like a dream. Simple fix for a change. I just hope my oil didn't get to contaminated with gas. Changed it and gave her some lucas. Time will tell.
Old Aug 2, 2007 | 03:18 PM
quicklook2's Avatar
quicklook2
handyman at home plate, he swings, he hits, it is an over the fence homerun.
the crowd goes wild.
Old Aug 2, 2007 | 03:23 PM
handyman43358
Haha in a baseball mood today quicklook? I'm glad ya found the problem roughrunner.
Old Aug 2, 2007 | 03:29 PM
quicklook2's Avatar
quicklook2
it is lightening and thundering like crazy here.
temp dropped 15 degrees in 15 minutes.
not good baseball weather.
also glad ya got er fixed roughrunner.
Old Aug 2, 2007 | 03:37 PM
netscaner's Avatar
netscaner
Quick, the gave is over and WE WON !!!!
Old Aug 2, 2007 | 03:40 PM
handyman43358
I wish it was raining here. I had to work up around the northeast side of Mt Gilead today, just south of Mansfield, and it was hotter than the devil. But what can ya do? Hopefully some of that rain makes it's way down here.. the corn here looks like mangled hell.
