Sponsored by: Real Truck
man tran ?
Old Jul 29, 2007 | 06:53 PM
yamaguy's Avatar
yamaguy
man tran ?
NO Kris, It's not what your thinking get your mind out of the gutter JK. What rpm do people with the ZF6 rev at 70mph, 65 mph ect... Also include rear-end ratio, and engine. Thanks
Old Jul 29, 2007 | 07:04 PM
Nikolai's Avatar
Nikolai
3.73, 5.4, 2000 rpm's @ 70 mph.
Old Jul 29, 2007 | 07:32 PM
mastercaster's Avatar
mastercaster
'05 6.0psd with 3.73 rear i turn exactly 2000rpm's @70mph.
Old Jul 29, 2007 | 08:21 PM
Beerstalker's Avatar
Beerstalker
You also need to know tire diameter, and if they have updated the PCM for tire size if you really want to compare these correctly.
Old Jul 29, 2007 | 10:35 PM
yamaguy's Avatar
yamaguy
Yea your right Beerstalker. I think a better question is what is the ratio of the overdrive gear in the ZF6? It sounds like it's almost the same as the 4r100 .72 ish if I remember. I knw that it has the granny gear, but I would hope that the od is a little taller as well.
Old Jul 29, 2007 | 11:35 PM
armymark's Avatar
armymark
33 inch tires,3.73, 6.0 PSD, 70 mph@2000 rpms.
Old Jul 29, 2007 | 11:51 PM
jbawilliams's Avatar
jbawilliams
I have an early 99 CC with 7.3 PSD. I have the stock tire size - 265-75 R16, and 3.73 rear end. 6 spd ZF6, I run about 2200 at 70 MPH. 2000 RPM gives me 65 exactly by my GPS.
Old Jul 29, 2007 | 11:55 PM
duffman77's Avatar
duffman77
2007 SRW F350, 3.73 with 18" Conti's (2WD version (Yes they are different))
1950RPM = 110 Km/h = 68 MPH
Yes the ZF6 OD is .72:1
Old Jul 30, 2007 | 12:47 PM
jbawilliams
I knew the 4r100 was .72:1 for OD, but I thought the ZF6 was .77 or .76:1 for OD. It was .77:1 for the ZF5.
Old Jul 30, 2007 | 02:05 PM
glenn Allen's Avatar
glenn Allen
early 99 7.3 DRW F350 3.73 rear on 215/85/16 factory tires turns 65mph at 2000RPM
Old Jul 30, 2007 | 03:34 PM
Fordfreak_24's Avatar
Fordfreak_24
03 v10, 35 inch rubber, 4:30 rear gear, 2000 at 60, 2300 at 70.
Old Jul 30, 2007 | 08:19 PM
F350-6's Avatar
F350-6
And here I thought I was the only one who set my cruise at 68.
02 f350 cc lwb srw 3.73 1900 rmp @ 68, 2000 @ 70 stock 265/75/16 (pretty sure that's the right size) Avg 19.85 mpg running empty and staying below 2000 rpm's with ranch hand front & rear bumper, steel tool box with about 400 pounds of tools.
bebyb
Sep 21, 2014 01:12 PM
frankat1
Jun 2, 2009 12:40 PM
Customz
Nov 1, 2005 05:12 PM
COBRAjrb
1978 - 1996 Big Bronco
28
Dec 2, 2003 08:21 PM
golf_wrench
1983 - 2012 Ranger & B-Series
Jun 3, 2003 07:39 PM
