Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Intake Update
Old Jul 29, 2007 | 06:48 PM
51dueller's Avatar
51dueller
Intake Update
I went out to Bucks and managed to find 2 of 3 missing pieces required to make my intake work. I got them off a late 80's Cougar since I realized that Crown Vic parts are incorrect. Ford changed the throttle body linkage since it's on drivers side instead of the passengers side. Gotta love Ford Interchangeability.
I now have coolant piping for my heater and intake.
Here's the difference between the Cougar/Mustang linkage vs the Explorer. The explorer one is facing the wrong way and has no connection for my AOD transmission.
Here I just bolted it all together for mock up and storage purposes. As you can see I still need to buy an aftermarket EGR spacer but haven't received shipping cost replies from people on E-bay. It's almost like they don't want to sell it.
Old Jul 29, 2007 | 10:51 PM
Fomoko1's Avatar
Fomoko1
Good planning to get it all before you get on the truck.
Are the Expy heads still there?
Old Jul 29, 2007 | 11:38 PM
51dueller's Avatar
51dueller
I bought my intake from a guy just outside of Saskatoon. He still has the GT-40 heads but doesn't know if he's gonna sell them. They would be nice but that would be another $350 and more $$$ to get them rebuilt. I'll stick with my D0OE 351W heads.
Old Jul 29, 2007 | 11:46 PM
Fomoko1's Avatar
Fomoko1
What is the hp advantage to the GT-40 heads with the proper cam, headers, ect?
Old Jul 30, 2007 | 12:00 AM
51dueller's Avatar
51dueller
It's about 15hp over my heads and about 25 hp over regular heads.
Old Jul 30, 2007 | 12:01 AM
Snowking's Avatar
Snowking
I'm assuming more fuel and/or compression.
Old Jul 30, 2007 | 12:04 AM
51dueller's Avatar
51dueller
They just flow better than the regular heads and have the same compression as my heads. The stock explorer engine is about 9.1:1.
I just tried to take the throttle shaft out of my throttle body but it uses roller bearings unlike the older bushing type ones. So I guess I have to grind the old linkage off with it still attached.
Old Jul 30, 2007 | 12:16 AM
Fomoko1's Avatar
Fomoko1
Sounds like it`s worth going after these heads so if you get the chance please check on them.
I do have 69 351/290 hp Cougar engine sitting around, are these heads close to the GT 40`s in performance?
I know the compression on these heads is around 10.7 but figure with the right pistons I should be ok.
Old Jul 30, 2007 | 01:21 AM
Dustin1690's Avatar
Dustin1690
Sounds like you scored some more good parts to complete the ensemble
Old Jul 30, 2007 | 07:23 AM
96sherm's Avatar
96sherm
you've definately did your homework on this one Nathan!! very interesting watching it form up!!
Old Jul 30, 2007 | 08:35 AM
Corner Gas's Avatar
Corner Gas
Nice find you got yourself.
Old Jul 30, 2007 | 09:01 AM
51dueller's Avatar
51dueller
Well I didn't save his number and his adds have expired on Kijji. Those Cougar heads are good (C9OE) and are almost as good as the GT-40 ones. They are slightly better than mine as they don't have emission bumps in the exhaust runner. Just you may need hardened seats as mine were made in 1974 which was at the end of the leaded gas.
I can grind the bumps out but then I have to disassemble my heads, then wash and re lubricate everything.
Old Jul 30, 2007 | 09:35 AM
51dueller's Avatar
51dueller
I just won an EGR spacer on E-bay for $20. Even if it costs $20 to ship the darn thing I still made out alot cheaper than the other ones.
EGR Spacer
Fomoko, I just remembered I have his e-mail address so if you want it, PM me.
Old Jul 30, 2007 | 10:30 AM
Fomoko1's Avatar
Fomoko1
If the 69-351 heads are almost as good as the Gt 40`s I`ll go with them.
Did you ever talk to Dan about the Crown Vic parts yet?
Old Jul 30, 2007 | 01:20 PM
preppypyro's Avatar
preppypyro
Ill have to try and find a good set of heads like those cougar heads. What would be the difference between them and those gt 40's?
