HELP Ford on Road Dead
Originally Posted by rebelchevy02
On my truck its a 20 amp fuse, #40 I also have the larger fuse block, so just double check your manual.
Originally Posted by F350-6
My manual said it was #40. It didn't look blown but I changed it anyway. Still no help. Anyone know what tools I will need? It looks like small sockets and a fuel line removal tool.
let me crawl under my truck and look, ill let you know in a few minutes..
Is there any way you can get a hold of atleast a test light?
Ideally 7mm short socket, 1/4 inch drive. 13mm deep socket, whatever ratchet, 9mm nut driver or wrench. Fuel line disco tool. If you dont have or cant get a disco tool, you can use small hose like for windshield washer fluid, cut it in half, open it up and slid it into the connector, and use a small bent flat head to push the last tab. There is one 7mm bolt that clamps the pump in place, and 3 13mm nuts that hold the bracket in place, on the outside of the frame is were they are located. 9mm is for the electrical connections, which the one side will have to be done once the pump is loose. Also, pull the fuse for the fuel pump before you start, just in case.
Yes I can get a test light, but it's pouring down rain right now. At least I was able to coast to an exit with a gas station that sells beer and had a hotel across the street.
What kind of town doesn't have an auto parts store but has a hotel? I guess I should count my blessings.
I've got a set of 3/8 and 1/2" drive sockets but no 1/4" drive. From what I can see that looks like it will work. I've got a really nice fuel line disconnect tool at home in the barn I used on my wife's F150. I guess I should start carrying that in the toolbox. I'll see if the mechanic will get one of those when he picks up the fuel pump.
The change out doesn't look hard at all. What am I missing, or what will I break when I try and do this?
Originally Posted by ryaneverk2
Have you confirmed that you're getting fuel? If you open the yellow drain lever on the fuel bowl, and turn the key to RUN without cranking, the fuel should pump out in a steady stream for a while (until the fuel pump shuts off).
7mm, 9mm, and 13mm, make sure you have those!
I just changed my fuel pump a couple of weeks ago. The new pump comes with a new nipple on the output side, so no disconnect tool is needed. The input side has a screw type of clamp on it also. It also comes with a complete brace that bolts onto the frame. thus, you don't have to remove it from the brace. the electrical connection is a plug type. I'm sorry you are stuck out there with out a good set of tools, or stuck at all for that matter. Best of luck getting it running again
#28
#29
Noticed the glow plug light will not turn off when I turn the key on. Drained the fuel bowl half way and it won't refill either with key or when try to crank. Could it be a fuse or am I screwed? Anyone know a diesel mechanic in Davis, OK
#30
Originally Posted by Tenn01PSD350
Hey, have someone turn the key and beat on that pump with something. Stupid failing electrical motors will sometimes start then. Just brushes armiture etc. Of course it will fail again quickly but at least you know the pump is the culprit. How many miles on the truck?
I may beat on it anyway just to make me feel better.
