aod problems
Old Jul 29, 2007 | 02:13 PM
OldRed4X4's Avatar
OldRed4X4
aod problems
my aod shifts hard into almost every gear and slams into reverse why would it do that in every gear and sometimes it shifts like a dream and it doesnt shift out of overdrive when slowing down untill your barly moving and shifs hard when it does unless i do it manually.
Old Jul 29, 2007 | 02:32 PM
andym's Avatar
andym
It would help if we knew anything at all about the truck it was in.
Old Jul 29, 2007 | 02:37 PM
OldRed4X4's Avatar
OldRed4X4
ok sorry 1987 ford f150 it has a 5.0 with 160,000 miles on it
Old Jul 29, 2007 | 03:11 PM
OldRed4X4's Avatar
OldRed4X4
and the truck is having idling problems again
Old Aug 1, 2007 | 01:13 PM
OldRed4X4's Avatar
OldRed4X4
Does any one have any advice or places to start
Old Aug 3, 2007 | 08:58 AM
Dukernc's Avatar
Dukernc
In order for folks to help you we would need to know which transmission you have? Has the transmission been serviced lately? It could be as simple as a dirty filter and fluid? If it' an AOD then it could be that the TV cable is out if adjustment? The cable can stretch over time. Need to establish a base line on what is ok and not. Hope this helps. Good luck!
Old Aug 3, 2007 | 03:01 PM
OldRed4X4's Avatar
OldRed4X4
i did mention it was an aod but not very clearly i dont post much i like to read all the other threads but to answer you ?'s the fluid was recently changed and i dont know about the filter or tv adjustment but maybe ill get er into the shop cus im afriad its not looking good and one more thing when i put it into reverse it sometimes shifts hard other times pretty smooth it does this when it is idling above a 1000 rpms than it is smooth could it be the TPS im just guessing from other things ive read here
Old Aug 21, 2007 | 06:58 PM
OldRed4X4's Avatar
OldRed4X4
ok i figured somthing else out it shifts hard when u lef off the gas right before it shifts this is mostly in town though and going into od on the highway if that helps
