turbo question
Old Aug 3, 2007 | 11:17 PM
6.0superduty's Avatar
6.0superduty
How would I be able to find out more info on my turbo? If I post some pics is there a way to tell by looking? Also, I usually shift at about 5200- 5500 rpms. Mostly a track car, but I like driving it on the street. It's a five speed, don't know if that matters.
Old Aug 9, 2007 | 11:16 PM
6.0superduty
Do I need to run a timing retarder? Also, what injectors and mass air should I get? I plan on running about 10lbs at about 5400rpms max. The car is a five speed. Thanks
Old Aug 11, 2007 | 07:55 PM
vaporloc's Avatar
vaporloc
This is old school but worth a little thought. Remember when chevrolet built a car called a Corvair? Some of them with the higher output (150/180 HP) engines were turbocharged. No waste gate was used. Turbo boost was limited to around 10 to 12 lbs. by use of a restrictive muffler and carb. This part won't help but timing was set at 24 degrees BTDC and a vacuum/pressure retard was used on the distributor to retard timing to 8 degrees as the turbo spooled up to full boost. I just wanted to pass this on about how pressure was limited way back when...So there are other means to control it. Also with a simple change to a more free flowing muffler, boost would climb to 15 to 18 psi. With that change if you used a 2 barrel Stromberg or weber carb. The little engine would boost itself all over the street. Now remember most non turbocharged corvair engines only made 90 to 110 horsepower from 164 cubic inches. So the idea did work.. Just thinking out loud..
Old Sep 22, 2007 | 01:31 PM
ami2loud's Avatar
ami2loud
ill give you a run down on my setup
B&G Turbo kit
T70 w/ .96 a/r exhaust housing T4 compressor & exhaust
Tial 38mm wastegate
HKS Super Sequential Blow off Valve
C&L 76mm MAF
42lb injectors
running 10psi ive been 10.65 @ 127mph
scottie2hottie
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
18
Feb 9, 2012 09:13 AM
mabc926
24
Jan 25, 2011 06:27 PM
rocknut
Feb 9, 2010 07:27 PM
87carbed
Jul 29, 2005 10:12 AM
RdBaron03
Aug 7, 2003 01:59 AM
