Sponsored by: Real Truck
manual to auto
Old Jul 28, 2007 | 02:52 PM
dualwheels66's Avatar
dualwheels66
manual to auto
I would like to replace the manual trans with an automatic. I have a 2006 F 350 cc dually. Anyone know of a shop that can do this swap?
Old Jul 28, 2007 | 03:48 PM
drbalazo's Avatar
drbalazo
im sure someone will be able to answer your question. Be prepared because its $$$ to do what you want.
Old Jul 28, 2007 | 04:06 PM
nhill2090's Avatar
nhill2090
ill take your old one
Old Jul 28, 2007 | 04:47 PM
dualwheels66
I'm not sure you would want it. It might be in need of repair.
Old Jul 28, 2007 | 04:54 PM
BareBones's Avatar
BareBones
Bear in mind it isn't just a tranny swap. New computer too?
Old Jul 28, 2007 | 05:10 PM
dualwheels66
I believe that the computer can be re-programmed. I also need the steering colum shifter, perhaps a different crossmember and other little parts. There was an article or website for a shop that did these swaps on a regular basis, so I know it is possible.
Old Jul 28, 2007 | 06:47 PM
Vijay's Avatar
Vijay
Seen my signature? it’s been like that forever now!….if you come across any shop that does that please let me know... I 'm trying to get mine converted to Manual.
I like everything about my truck except the automatic trans…for what ever reason I just hate it. Manual trans gives more control if you enjoy driving and I sure do.
Old Jul 28, 2007 | 06:49 PM
Vijay's Avatar
Vijay
Do have the link for that site?
Old Jul 28, 2007 | 07:03 PM
dualwheels66
No that is what i am trying to find. I am going through all of my back issues of magazines, I know I have it somewhere.
Old Jul 28, 2007 | 07:53 PM
powerstroked162's Avatar
powerstroked162
Brians Truck Shop or better known as BTS transmissions does a manual to auto swap in house. Why you'd want an auto I dont know but you'll regret it when you get ya a slushbox. Good luck though
Cowboy Steve
Old Jul 28, 2007 | 08:24 PM
dualwheels66
A auto has got to be better than the manual. I am already on my second manual trans and I am pretty sure I will need a third.
Old Jul 28, 2007 | 08:26 PM
powerstroked162
What're you doing to them????? I have never heard of people goin through manuals. Maybe cluctchs cause they didnt know how to shift, but eegads man.
Cowboy Steve
Old Jul 28, 2007 | 08:31 PM
redford's Avatar
redford
FTE Leadership Emeritus
Seriously, what in the wide wide world of sports are you doing to the manual transmissions? How are they breaking?
I've seen both gas and PSD owners abuse the bejeezuz out of the ZF trannys and they still go 200K miles without any major issues.
Also, I think you'd find it more cost effective to just trade your truck for one with an automatic. If you are eating ZF trannies at a rapid rate, I wouldn't expect an automatic to hold up to the same abuse.
Old Jul 28, 2007 | 08:54 PM
dualwheels66
At around 23k the input shaft broke in two pieces, all of the bearings were either cracked or burned from too much heat. The mechanic said that possibly the factory did not put enough fluid in it from day one. That statement could not be verified from Ford or anybody else. There were never any leaks from the trans or anywhere near it. So the truck was sitting at the shop for two weeks while I sat at home because I cannot pull my work trailer with a Windstar. About 3 weeks after the truck was fixed, another customer came in with a similar problem. He too had a bearing failure and needed a new trans. Long story short, they finally called Ford and found out that after any catastrophic trans failure, the pressure plate must be changed. Mine was never changed thus the second trans is starting to make the same noises that the first one did. More than likely I will need another trans. Sorry for the long post but it felt good to vent.
Old Jul 29, 2007 | 04:42 PM
Vijay's Avatar
Vijay
Cowboy Steve
Steve,
Do you know if they do auto to manual too? I seriously want to get rid of the auto trans ASAP. <O</O
