replacing 93 E4OD tranny
Old Jul 28, 2007 | 10:30 AM
budperm's Avatar
budperm
HI Everyone!
I bought a 93 F250XL 4X4 5.8L E4OD with 133K miles last fall. Last month While towing my Wrangler, the Tranny blew front seals and pewked out all the fluid 100 miles from home.
I am installing a remanufactured E4OD that is upgraded to 1997 specs. I remember reading somewhere that I should replace the MLPS and PCM.
The MLPS replacement makes since,going to new style with gaskets. My major concern with the replacement is how to align it. The only thing I have been able to find was a forum blurb that told me to start raised truck and place tranny in reverse. Then I should adjust sensor to center of range that causes the backuip lights to come on. Is this correct?
The PCM replacement confuses me. Can't I just have it reprogrammed? Remember my F250 is a '93. Please help me fill in the blanks so that I have a better understanding of the problems that require an updated PCM.
Thanks for your help!
Bud
Old Jul 28, 2007 | 07:33 PM
mhg's Avatar
mhg
mlps change is a good idea
I dont think you need to change the pcm though
everything I have read does not indicate that the pcm needs any upgrades
check out www.fordfuelinjection.com as they have
a section dedicated to the e4od and its electronics
Old Jul 28, 2007 | 07:45 PM
lostin90s's Avatar
lostin90s
there is an adjustment line for nuteral on MPLS . I put new MPLS on and with tranny in neutral adjust(there is slotted holes. MPLS so line lines up . Never had any problems
Old Jul 28, 2007 | 09:55 PM
shuttlevalve's Avatar
shuttlevalve
was it a ford reman?? i bought one last year from ford and it came with the new and improved MLPS and a new connector. Hell it was already full of oil. I put it in and added 2 1/2 qts and i was on the road.
Old Jul 28, 2007 | 10:12 PM
budperm's Avatar
budperm
wow! Thanks for the ggreat link.... I have been reading for 2 hours with more to come.
Thanks
Bud
Old Jul 28, 2007 | 10:20 PM
budperm's Avatar
budperm
I can see the alignment lines on the new MLPS, the problem is my son had to drop the pan and swap the manual shift lever shafts between trannies. The new tranny had a one peice lever and shaft (wrong lever and orientation) so I don't know where neutral position is on manual shift lever. Right now, The lever is at 12 o'clock and the switch is aligned to it's marks and the hold down bolts (2) are centered in the MLPS slots.
I'll just have to make sure I don't start it unless the wheels are off the ground.
Thanks for the feedback!
Bud
