steering linkage
Old Jul 27, 2007 | 09:11 PM
Antony c.'s Avatar
Antony c.
Question steering linkage
I done a disk brake conv. on my 65 ford f-100 and when I went to hook up my linkage to my spindles one side fit fine(other than grinding a 1/8 off to allow for the carter key to fit properly) the other side I could not get the tie rod end up throught the spindle. Will I have to take something loose.?[/QUOTE
Old Jul 27, 2007 | 09:21 PM
ddavidv's Avatar
ddavidv
Depending on the linkage (65, or the donor truck?) you may have to adjust the tie rods in or out to reach the spindle. I don't remember having to do this on mine, just that the alignment was way, way off when I was done bolting it together.
Old Jul 28, 2007 | 09:07 AM
daveengelson's Avatar
daveengelson
If recall, on my 65 had to go back to salvage yard and get the tie rods and pitman arm off the donor truck.
dave
Old Jul 28, 2007 | 11:13 AM
66beater's Avatar
66beater
Who makes good replacement rods?
The doner truck's ball joints could be used as a baby rattle.
Old Jul 28, 2007 | 11:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NAPA prolly sells the best replacement parts.
Tie rods, tie rod ends, and draglinks have ball studs, not ball joints. Ball joints are a different part entirely, and weren't used on 2WD trucks till the 1980's.
btw: It's a Cotter key, not a carter key.
