Transmission trouble?
Old Jul 27, 2007 | 05:38 PM
windstarharv's Avatar
windstarharv
I have a 98 Ford Windstar, 3.8. When I first start the van and shift into reverse, nothing happens, no clunk, no engagement. It I shift into drive and then back into reverse then its ok. After this it shifts into reverse with no problems. What kind of trouble am I looking at? Thanks
Old Jul 27, 2007 | 08:13 PM
ReAX's Avatar
ReAX
Start with checking your fluid level. Automatics have a worm trail that fluid has to go through in order to change gears, if you don't have enough fluid, it may be taking a while to prime and build sufficient pressure.
I think it's a valve body issue, but I am not a transmission expert.
dsantorii
2004 - 2008 F150
Mar 17, 2014 12:24 AM
ford197267
May 2, 2012 09:35 AM
